1995 Dodge Gr Caravan Horn Troubleshooting
bcmcjeepbcmcjeep Posts: 3
edited March 2014 in Dodge
Can somebody tell me how to go about
troubleshooting a horn on my 95 Caravan? I have a
chilton's manual which shows the wiring diagram but
I can't see the horn or the fuse and circuit
breaker it shows in the book. I would think this
should be a relatively simple procedure. Thanks.
  • Looking in my Chilton's Manual I realized I had the recall on the Air Bag module done about the same time the problem appeared. One of the steps is to disconnect the horn connector, I bet they forgot to hook it back up. Will schedule for appt with dealer to check it out.
  • I finally found the problem. It turns out the Horn is on the same fuse as the Cigarette lighter. I only found out when I went to plug in an accessory and it didn't work. Replaced the fuse and both work fine now.
  • pat455pat455 Posts: 603
    Glad you found your problem. I'm sorry that no one around here offered you any assistance on this, but let me take a minute to explain how Town Hall differs from the usual question and answer boards all over the internet.
    Here we tend to focus discussions on broad topics of general interest. It is within these broad topics that questions such as this one and the one about your heater in the topic you created today tend to get answered more readily.
    What you should do is use the Topic Search feature on the left side of the page for a good place to post your questions. If you can find an existing topic that is relatively active, you are more likely to get your questions answered than if you just start up a whole new topic directed at no one in particular.
    For instance, searching for Grand Caravan returns several active topics in our Vans conference, and another one here in this conference.
    Give it a try!
    Pat
1995 Dodge Gr Caravan Horn Troubleshooting — Car Forums at Edmunds.com
