rain water comming through blower motor
I have a 2003 dodge caravan and when it rains it leaks out the blower motor behind glove box. I hosed down front window and narrowed it down to passenger side of window. How is it possible to come through blower motor. E.G. if I pour 2 Lts of water over the left window 2 Lts come out of blower motor. It Pours out not a light trickle.
Any help would be greatly appreciated.
  • You might want to remove the wiper motor assembly and see if there is a drain hose and where it leads to.
  • ralkaralka Posts: 72
    sounds like water is getting into the air vent. check to see if the plennum drain hoses are clogged with debris or pinched shut
  • I have this same problem and am wondering if either of these suggestions worked to fix the problem or if you discovered something else that might be causing it. Thanks for any help you can give me.
rain water comming through blower motor — Car Forums at
