Cadillac CTS XM Radio
kjosephkjoseph Posts: 3
edited October 2014 in Cadillac
I recent bought a 2004 CTS with factory installed XM. However, when I cycle through the bands I only get AM-FM1-FM2. How do I get XM back on my radio reciever?
  • paopao Posts: 1,867
    when cycling throught you should get XM band with channel 1, their advertisement channel on shouldnt cycle throught as you stated......are you sure you have XM? you have the little black module antenna.....dont know where on the CTS its located.....
  • kjosephkjoseph Posts: 3
    Yea, I'm sure. I have the, factory installed, little black "XM" radio antenna on the roof - next to the "on-star" antenna on the back window. It also shows in the GM VIS that it is equipped with On-star and "XM". I also have the XM Radio ID that is listed on the VIS (Vehicle Inquiry System).
    so if you get the ID...then you will probably have to get the subscription activated and have them pulse the radio.......but you still should get the XM advertisement channel 1 when you toggle through the band selection
    I called XM and they sent the "pulse" out. However, getting back to my original question. Why am I not able to get the XM1 - XM2 to come up on my radio without taking it to a dealership and paying BIG CASH!!!!!
  • imsysimsys Posts: 1
    Did you ever find an answer to this? I have the same issue... and the xm worked a month ago :mad:
  • wrupertwrupert Posts: 1
    I have the same problem with my wifes 2004 SRX, anyone have an answer?
Cadillac CTS XM Radio — Car Forums at
