Center Bore on Chev Aveo
djay75djay75 Posts: 1
edited July 2014 in Chevrolet
I can't find what the center bore is on this car. it's a 2006. I know it's a 4*100 bolt pattern.
Thanks. If anyone knows, they know more than 4 dealerships....
Dave
  • esjnzresjnzr Posts: 1
    2004 ENGINE
    Engine Mechanical - 1.6L (L91) - Aveo
    SPECIFICATIONS
    FASTENER TIGHTENING SPECIFICATIONS
    Fastener Tightening Specifications
    Application
    Specification
    Metric English
    A/C Compressor Mounting Bolts 27 N.m 20 lb ft
    A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
    Air Filter Housing Bolts 12 N.m 106 lb in
    Alternator Adjusting Bolt 20 N.m 15 lb ft
    Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
    Auxiliary Catalytic Converter-to-Exhaust Manifold
    Nuts and Bracket Bolts
    40 N.m 30 lb ft
    Camshaft Cap Bolts 16 N.m 12 lb ft
    Camshaft Gear Bolt 67.5 N.m 49 lb ft
    Camshaft Pressure Plate Bolts 10 N.m 89 lb in
    Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
    Coolant Pump Retaining Bolts 10 N.m 89 lb in
    Coolant Temperature Sensor 20 N.m 15 lb ft
    Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
    Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
    Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
    Cylinder Head Bolts - Camshaft Support Housing
    and Cylinder Head Mounting Bolts
    25 N.m+60°+60°
    +60°+15°
    18 lb ft+60°+60°
    +60°+10°
    Electronic Ignition System Ignition Coil Mounting
    Bolts
    10 N.m 89 lb in
    Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
    Engine Mount Bracket-to-Engine Mount Retaining
    Bolts
    60 N.m 44 lb ft
    Engine Mount Retaining Nuts 40 N.m 30 lb ft
    Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
    Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
    Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
    Exhaust Manifold Nuts 25 N.m 18 lb ft
    Flexible Plate Bolts 60 N.m 44 lb ft
    Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
    Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
    Flywheel Inspection Cover Bolts 12 N.m 106 lb in
    Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
    Fuel Rail Retaining Bolts 25 N.m 18 lb ft
    MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
    http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
    ENGINE MECHANICAL SPECIFICATIONS
    Engine Mechanical Specifications
    Intake Manifold Retaining Nuts 25 N.m 18 lb ft
    Intake Manifold Support Bracket Lower Bolt-to-
    Engine Block 40 N.m 30 lb ft
    Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
    Lower Timing Belt Cover Bolts 10 N.m 89 lb in
    Oil Pan Retaining Bolts 10 N.m 89 lb in
    Oil Pressure Switch 40 N.m 30 lb ft
    Oil Pump Retaining Bolts 10 N.m 89 lb in
    Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
    Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
    Oil Pump Rear Cover Bolts 6 N.m 53 lb in
    Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
    Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
    Rear Timing Belt Cover Bolts 10 N.m 89 lb in
    Spark Plug Cover Bolts 3 N.m 27 lb in
    Spark Plugs 25 N.m 18 lb ft
    Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
    Throttle Cable Bracket Bolts 8 N.m 71 lb in
    Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
    Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
    Transaxle Bell Housing Bolts 75 N.m 55 lb ft
    Transaxle Brace Bolts 40 N.m 30 lb ft
    Transaxle Torque Converter Bolts 65 N.m 48 lb ft
    Upper Timing Belt Cover Bolts 10 N.m 89 lb in
    Valve Cover Bolts 10 N.m 89 lb in
    Application
    Specification
    Metric English
    General Data
     Engine Type 4 Cylinder - In-Line
     Displacement 1598 cm3 97.51 in3
     Bore Stroke 79.0x81.5 mm 3.1x3.21 in
     Compression Ratio 9.5:1
     Firing Order 1-3-4-2
     Maximum Power - At 6200 RPM 77 kw/103.3 hp
     Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
    Cylinder Bore
     Diameter 79 mm 3.1 in
     Out of Round - Maximum 0.0065 mm 0.00025 in
     Taper - Maximum 0.0065 mm 0.00025 in
    Piston
    MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
     Diameter 78.970 mm 3.07 in
     Clearance to Bore 0.03 mm 0.0012 in
    Piston Rings
     Ring, End Gap - Top Compression 0.15-0.3 mm 0.006-0.012 in
     Ring, End Gap - Second Compression 0.3-0.5 mm 0.012-0.019 in
     Groove Clearance - Top Impression 0.05-0.09 mm 0.0019-0.0035 in
     Groove Clearance - Second Compression 0.06-0.10 mm 0.0024-0.0039 in
    Piston Pin
     Diameter 18 mm 0.708 in
     Pin Off-Set 0.5-0.7 mm 0.019-0.027 in
    Camshaft
     Lift Intake 7.2 mm 0.283 in
     Lift Exhaust 7.2 mm 0.283 in
     End Play 0.1-0.25 mm 0.0039-0.0079 in
     Journal OD - No. 1 29.94 mm 1.179 in
     Journal OD - No. 2 26.94 mm 1.061 in
     Journal OD - No. 3 26.94 mm 1.061 in
     Journal OD - No. 4 26.94 mm 1.061 in
     Journal OD - No. 5 26.94 mm 1.061 in
     Bearing OD - No. 1 30.01 mm 1.181 in
     Bearing OD - No. 2 27.01 mm 1.063 in
     Bearing OD - No. 3 27.01 mm 1.063 in
     Bearing OD - No. 4 27.01 mm 1.063 in
     Bearing OD - No. 5 27.01 mm 1.063 in
    Crankshaft
     Main Journal - Diameter - All 55 mm 2.17 in
     Taper - Maximum 0.005 mm 0.0001 in
     Out of Round - Maximum 0.004 mm 0.0001 in
     Main Bearing Clearance - All 0.026-0.042 mm 0.001-0.00165 in
     Crankshaft End Play 0.1 mm 0.003 in
     Connecting Rod Journal - Diameter - All 43 mm 1.69 in
     Taper - Maximum 0.005 mm 0.00019 in
     Out of Round - Maximum 0.004 mm 0.00015 in
     Rod Bearing Clearance - All 0.019-0.07 mm 0.0007-0.0027 in
     Rod Side Clearance 0.07-0.242 mm 0.0027-0.009 in
    Valve Stem
     Valve Lash Compensators Hydraulic
     Face Angle - All 45-45, 25 degrees
    MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 3 of 330
    http://
  • autopureautopure Posts: 1
    Steel wheel 15x6 4H PCD100 Center Bore 56.1mm Offset 35--42mm
