Nissan Pathfinder Blowing Air
maliboo96maliboo96 Posts: 3
edited April 2014 in Nissan
I have a ffiend with a late 90's early 2000 pathfinder. When she turns tha blower motor to off position it still blows air from the passanger side vents. Any suggestions >??
  • tidestertidester Posts: 10,109
    When you say "it still blows air," do you mean it still comes out with the same force as with the blower on? I think you'll still get little air flowing through the vents with the fan off. To shut it off completely, you will need to also close the vents.
    SUVs and Smart Shopper
  • maliboo96maliboo96 Posts: 3
    Yes with the air on it seems fine but when she turns the blower to the off position there is still air blowing out the pass. vents. Not cold air kinda luke warm and yes a noticable amount not just flow thru .
    I don't know what the controls are like in the Pathfinder but is it possible to have the fan off while the air control is set to recirculate? If it's set to recirculate with the fan off you should not get any flow through.
    Well it has always worked just fine but all of a sudden just started. So much that it is very noticiable. And she is turning it off the same way she has always turned it off. But I will look at the controls better.
Nissan Pathfinder Blowing Air - Car Forums at Edmunds.com
