2008 Chevy Equinox headlamp condensation ... normal or not?
I am looking at purchasing a 2008 Equinox. I noted moisture buildup on the inside of the headlamp lens. When asked about it the dealer rep said it was normal and of no concern, adding if I wanted he could have a mechanic "blow it out". Is there anyone out there that can confirm or deny what the dealer is telling me?
If it was normal all the other Equinoxes (or any other car for that matter) would have damp lens.
Find another dealer, or at least another salesperson.
should the effected lenses be replaced under the bumper to bumper warranty since this is a chevy certified preowned vehicle which carries a 12 month 12,000 mile bumper to bumper warranty?
I suppose it's possible that the dealer went through a car wash or pressure washed the 'Nox and got some moisture in the headlamps. If so, it's possible that blowing out the excess could cause it to clear up in a week.
Some dealers will try to reseal the grommets or may even toss desiccant packs in with the bulbs. Or they'll find a crack and put some silicone on it. Or they'll try adding more air vents (most designs have 2 or 3 vents to lower the humidity level inside the headlamp assembly).
If the condensation is constant, my guess is that it either has a bad seal somewhere (like the grommet around the bulb access) or cracks in the lens.
Best permanent fix is new headlamp assemblies I think.
The solution was to take out the headlamp assembly from the car, blow all the water out and let it dry, and then applying silicon sealant to the length of the seam. That was my case, your mileage may vary.
I have a 2007 Chevy Equinox that stayed in the service dept for years with blown bulbs due to condensation. Finally warranty said no more to replacing light housing. So Chevy's remedy was to drill a tiny hole at the bottom, allowing the condensation to evaporate. STILL dealing with condensation, but not as much!!!
