Pontiac Grand Am
szerfasszerfas Posts: 53
Continuing on from 1999 Pontiac GrandAm...
My gas mileage in the SE1 V6 has been around 23 miles to the gallon with a mix of city and highway. Probably more highway then city though. I too have been good about not hot rodding around since it should still be on break in. I am hoping that it at least averages 25 after break in.
  • tffkaptffkap Posts: 11
    I have had similar results with my Alero. It is basically the same car with the same engine. When I started out, horrible milage. I mean like 20 on the HIGHWAY! Now it is better after 5500 miles. It is closer to 25. I doubt it will ever get to the 28 like they said on the sticker.
  • I'm thinking of buying a 1999 Gran Am GT-1 or waiting until the 2000's come out. Anybody have an idea when this will occur? Also, I would like to get any feedback on the major problems I've heard about the GT:
    Poor gas mileage
    Wind Noise
    Very stiff suspension, feeling all road irregularities
    Back up lights filling with dirt and water
    Stiff, uncomfortable seats for long drives
    Leaking door seals and trunks
    Poor legroom for front passenger
    Chips in hood paint
    Dead spot in center of steering control
    Poorly aligned door panels, etc.
    Were most of these problems encountered with cars built in 1998 during the GM strike?
  • jrbushjrbush Posts: 1
    Well I appreciate the responses that I have gotten from my gasmileage question. I took the GT on its first highway trip today and got about 26 miles to the gallon. That is not too bad but I was hoping for better. Something else has occured to me. Has anyone noticed that the tire pressure seems rather soft? For instance my car door indicates that the tire pressure should be at 30 psi, which to me seems very low. Therefore has anyone else got a different tire pressure for their GT. I wouldn't normally worry about it but the tires are rated up to 44 psi and 30 just seems too low. This is my 4th car and I have never had a car tire that was inflated at anything less than 35psi. Anyway my point is that if the tires are too soft then that could be affecting the gas mileage. Nevertheless any comments on this matter would be appreciated.
  • I just purchased a 99 Grand Am SE1 today, but won't actually get the car for another day. I went and looked at the car tonight with a friend just because I was so excited to see it for the first time (it just arrived tonight at the dealership). while looking at the car, my friend an I joked a bit about racing the two cars once I get mine and both agreed that my Grand Am will definitely be much quicker off the line do to the V6 3.4 liter engine I elected to get. Though the car is supposed to be somewhat quick off the line, I wondered if it would shut down at a certain speed. Does anyone that likes to speed a bit have any comments on how their car performs above the 70 mile an hour mark? My friend felt that it would shut down, but I'm dying to prove him wrong by blowing him away!
  • mstan1mstan1 Posts: 9
    I purchased a 1999 GrandAm SE2 in February. Some people have mentioned chips in the front hood. Is this an inherent defect? I just thought it was from road construction. If it is a defect, does Pontiac recognize this and fix it ? I have absolutely no other complaints. The car is red with a air-foil on the back, has good MPG (28.5 hwy and 25 city/hwy). No leaks or anything.
    I've been polishing and waxing it with Meguiars in my spare time. It always looks slick. My wife thinks I'm nuts spending so much time detailing the car. I even bought all cotton USA bath towels for polishing and waxing.(as suggested from Zaino site)
    I was cruising along just 2 days ago at 75 MPH and I really had to look at the speedometer to see that I was going so fast. I couldn't even tell.It's a real smooth ride!
  • hugobeckerhugobecker Posts: 45
    matty11276 - I don't have any first hand experience with Grand Ams and speed limiters, but most manufacturers limit the top speed (using the ECU) to the speed rating of the OEM tires. On the V6 Contours equipped with Firestone Firehawk tires the speed is limited to 112 MPH. I seem to remember that the speed of some GM cars is limited to 105 MPH.
    *_DON'T_* run it to the limiter the first day you get it though, wait until after the break in period (or better yet give it a thousand miles and one oil change) before really getting on it. Your new car will last a little longer if you do. Check your tire pressures before making any high speed runs also. Underinflated tires can be dangerous at speed.
  • szerfasszerfas Posts: 53
    The fastest I have had my SE1 V6 to is a little over 75 miles. It was very smooth at that speed. For how smooth it was it might as well have been 50.
    I have not washed mine yet once. I wanted to make sure that I did not use the wrong thing and put swirls in the clearcoat or anything. When you wash your do you spray it then apply the polish. I assume that at some point it gets dirty enough that you have to wash it before you can polish it. Also for the rims do you use that no touch ArmorAll on it? Just curious, thanks.
    That does not seem like a great deal. Those miles that you are giving up are going to be the best ones for it. I like to keep my cars a long time and how it was treated for those first few thousand miles can make a big difference on how it lasts. I would shop around or getting a lower model new one. I think you will be happier in the long run. They have some rebates and financing going on right now too.
  • janine9janine9 Posts: 1
    i would like to know what the difference betweern the ram air and the plain v6? it only makes 5 more horse power. why pay that much more?
  • The ram air is Pontiac's way of saying intercooler. While having only 5 more ponies the gear ratios are different than in the se and this leads to much quicker takeoffs.
    You are not only paying for the engine but remember the GT comes with 4 wheel disc (se front disc rear drum) and "sport" handling, and the rims and tires are different. The GT has low profile tires. Also the exhaust system is different.
    The thing that I liked about it was that I needed to option alot of things to fully load a se (14 I think) but with the GT I needed only to include 4 options for my car. I left the chrome wheels and leather off.
    Besides I think the engine has more than what Pontiac is listing... I will have to check that out
    How much does a maxed out Grand Am GT sticker for?
    I think I've answered my own question. Digging in Edmunds, a maxed out GT1 lists at 23,355 (w/o shipping). Interesting in that I own a '99 SVT Contour that stickers for just $300 more.
  • L8_ApexL8_Apex Posts: 187
    Pontiac's "Ram Air" has no relationship to an intercooler. The Ram Air is simply a less restrictive intake that, if true in name, uses the velocity of the car to force a little more outside air into the induction system. "Ram Air", like "Wide Track" is more marketing than engineering but the rest of the improvements you've listed are genuine.
    Intercoolers are typically used in supercharged or turbocharged vehicles to cool the intake charge for a greater charge density. It's a small radiator of sorts.
  • ursridharursridhar Posts: 1
    I tried shooting up to 100 and cruising at 80 in my SE1 V6. It's absolutely smooth. But for the traffic conditions I probably could have done a little more.
  • That teaches me to listen to a salesman...oh well I still love mine.
  • karnkarn Posts: 8
    I know this may be a little off the subject, but does anyone know how to find the paint code for the 99 grand am gt. I read the manual which told me to look under the spare tire cover. Did that and found 45+ codes, but they don't specify what the codes belong to. My car is a lease so I'd rather not go to my dealership for the touch up paint I need. Also, is anyone having problems with the steering seeming to loose at times and pulling during hard stops? I only have 3100+ miles and don't know if it just needs an alignment or not. Hopefully, I'll be taking the car into the dealership soon, but I would like to touch up my shopping cart dings before doing so. (That's if I can figure out the darn paint code for topaz gold metallic!!!!!)
  • toblongtoblong Posts: 1
  • basasjebasasje Posts: 1
    Has anyone noticed a rattling noise coming from the back of the 99' Grand Am??? It seems like something is loose in the back but i really only hear the noise when i accelerate. I plan to take it into the dealer when i get a chance.
    When I brought my '99 GrandAm SE2 in to the dealer for the 5,000 mile checkup and oil change, the service manager said that they were aware of the CHANGE OIL light coming on as early as 1,200 miles. Mine came on at 5,000 mi. The dealer in your area should also be aware of this and it should be taken care of.No other problems with mine.
    Sorry Jeb, my message was for toblong-
  • sarnold1sarnold1 Posts: 1
    I'm looking to buy a first car for my teen. There's a clean '92 Grand Am w/excellent care history, no accidents but high mileage (136,000). Can anyone tell me if these cars are still reliable once the milage gets high?
  • verndvernd Posts: 3
    I purchased my 99 GT1 fully loaded with leather and the chrome wheels and I love it. I average 24.5 mpg in combined driving. I already have 3800 miles on it and it is only 2 1/2 months old. The hood getting chipped is from road debris. On the expressway, rocks fly up and skip across about midhood.
  • angeladenangeladen Posts: 1
    I am considering purchasing a grand am se2 -- but while test driving, I felt that the large headrest blocked my view out the back. The mirrors seemed more than adequate, but I am concerned about blind spots with changing lanes and gauging distance while backing up. everything else about the car was fairly impressive. has any recent (short) buyer experienced visibility problems? any input is much appreciated.
  • melissasmelissas Posts: 1
    Reading all of these is very informative, I have been looking at purchasing a 99 GT1 Sedan, has anyone asked their dealer about the paint chips, everyone is discussing? If so, did they give you a reasonable explanation? For the most part you all really like the cars, I haven't really heard a negative person on here!
  • bogackibogacki Posts: 1
    All Grand Am fans:
    Look forward to the new Grand Am Supercharged/Touring edition of the current Grand Am GT. From what I've read, ASC and Pontiac are close to releasing the car into production. In fact, almost all the mods are production ready. The car is incredible! Watch out Grand Prix GTP owners! Basically the car is the new Grand Am GT with the following additions: a Magnusson-Eaton designed supercharger unit, 18" multi-spoke wheels and tires, modified exhaust system, "true" Ram Air designed hood, BMW M3 style ground effects with modified wing, and Recardo leather seats (front and back). The only mod needed to be done to allow the car to meet standard warranty is a modified transmission. This will either be a modified version of the present tranny used in the all new Grand Am's, or a replacement with the 3800's. Although the head designer of ASC wants to see the car get a 5-speed manual. Wouldn't that be great! The car has been track tested and a 0-60mph time has been confirmed at 5.9! That time was taken with the stock 4spd automatic transmission, and on stock 16" Eagle RSA's! Talk about incredible! And the supercharger is only putting out 5psi of boost! Imagine the performance after a pulley changeout. There is no reason that it can't be pushed to 8 or 9 lbs. My guess is that the car can be brought down to the low 5's (0-60). I'll have to look at the article again and see what the 1/4 mile time was. This car is definitely Pontiac's tuning future. If they indeed go with a stick, watch out Camaros, Firebirds, Mustang Cobras (and maybe even Vettes).
    I have had my GrandAm SE1 for about a month and have noticed what you are talking about. At first it bothered me but at the same time I noticed how big and well placed the side views mirrors are and now the headrests do not bother me so much. I think if you get the upgraded interior(SE2 maybe) the headrests are of the design with the hole through them. That might help you. I still look to the side to change lanes but the side mirrors are about the most useful I have found in any car I have driven.
    Happy motoring.
  • ethbagethbag Posts: 1
    I'm getting ready to buy my first new car and at this point it's the grand am GT sedan. From what I've seen I love the thing and I really haven't heard many negative things about it. I'm looking for a somewhat sporty sedan and this one seems to be the best for the price. Does anyone have any complaints or criticisms about the vehicle? Any great praises?
  • ethbag: I got my Grand Am GT sedan in May. Now I would sing about it but I can't carry a tune in a suitcase.
    The only complaint I have about the car is the rearview mirror creates a large blindspot. Now this might be caused by my height (6'2") or the way I happen to sit in the car. Once I discovered the blind spot and learned to correct my driving style to avoid it I can find no other faults with it.
    I am more than happy with my Grand Am.
  • mantamanta Posts: 4
    Can I ask you how much you paid for your GT, and what options did you get? I'm in the market for an SE1, but was just wondering. Any help I can get in considering Canadian prices is much needed!
  • aam1aam1 Posts: 26
    I will be getting a Grand Am SE1 in the next 2-3 weeks. Would appreciate any advice and suggestions so that I can get the best car at the best price.
Pontiac Grand Am — Car Forums at
