Towing a 1995 AWD Impreza
robdog13robdog13 Posts: 8
edited March 2014 in Subaru
I'm looking to tow a 1995 AWD impreza using a tow dolly and wanted to know how i need to do it. Are there any drive shafts or linkage that needs to be removed or adjusted ? Thanks for any info.
  • ateixeiraateixeira Posts: 72,587
    Manual or automatic?
    Manuals can be towed with all 4 wheels on the ground. The visous coupling allows for enough slip.
  • It is automatic. Thanks
  • xwesxxwesx Fairbanks, AlaskaPosts: 9,626
    How far are you towing it?
    2008 and 2010 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup, 1974 Ford Pinto Wagon
  • About 325 miles. Texas to Arkansas
    Okay, then if you are towing with the rear wheels on the ground, you should remove the driveshaft between the rear axle and the transaxle.
  • Thanks alot.
Towing a 1995 AWD Impreza - Car Forums at Edmunds.com
