2008 V6 Engine will not turn off
twj51twj51 Posts: 1
edited June 2014 in Mitsubishi
On occasion my 2008 Outlander XLS 3 Liter V6 engine will not shut off when I turn the ignition key to off. When this happens I have to disconnect the battery and remove the engine relay in the fuse box to get the engine to shut down. I have had this fixed once by the dealer (faulty ignition sensor) who said that this was the first time they had ever encountered this problem. Now after 2 months it is happening again. Anyone aware of this issue and is there an easier way to shut off the motor at least until I can get into a dealer?
  • tidestertidester Posts: 10,059
    Someone else had a similar problem with their Dodge Durango. Here are some tips for shutting the engine down.
    I suspect your key switch is defective and can either be repaired or replaced.
    SUVs and Smart Shopper
2008 V6 Engine will not turn off — Car Forums at
