Fix for broken Door handles
Okay, get the screw driver tip for the three door screws.
Pull the top edge out so you can get to the break.
with a tiny - think paperclips thickness! - drill bit, drill a hole through the two broken sides.
Insert paperclip (straightened) through the holes and bend it back on itself .
Use epoxy or similiar material to Lock the paperclip in place.
Let epoxy material cure.
Paper clip does not bend with the door handle operation, should outlast your ownership.
