ABS/DOOR CHIME on when driving 99 pont bonneville
I have a 99 Pontiac Bonneville, 3.8l sse model with 150k
I drove my car thru a bad rain storm last night, and this morning when I tuned on my card I noticed the ABS warning light stayed on, then the door chime kept dinging, driving me nuts.
Something had to of got wet, any suggestions???
Where is that door chime reley, would like to set it on fire right now.
thanks for the help
  • I have a 2000 Bonneville that when driving over 45 and braking the ABS pulses until the speed drops to 45 then stops. The problem started right after I had a tire go flat and replaced. The tire pressure light came on when the new tire was installed. I reset the warning light and it has not come back on. Shortly after the ABS pulsing started. I replaced the rotors pads and calipers on the front but the problem is still there.
