2010 CR-V Cargo Tray + Cargo Shelf
tornado1973tornado1973 Posts: 1
edited August 2014 in Honda
Planning to get a 2010 CR-V EX-L, which comes with the Dual Deck Cargo Shelf -- http://www.bernardiparts.com/Products/Honda-Cargo-Shelf-%28CR-V%29__84400-SWA-XX- X.aspx
The Cargo Tray is an option -- http://automobiles.honda.com/cr-v/accessory-detail.aspx?Accessory=CRV0010043
The Dual Deck Cargo Shelf "hides in the floor when you don't need it."
Can one stow the Shelf in the floor if the Tray is in place? If so, does the Shelf go on top of or underneath the Tray (presumably underneath)? If not, is there any point in having both the Shelf and the Tray?
  • steverstever Viva Las CrucesPosts: 51,051
    I think the cargo tray is a good idea. The cargo shelf on the other hand....
    I had a cargo shelf in my minivan and it was pretty useless. Mostly got in the way. Often I didn't have the third seat pushed all the way back and that made it worse.
    If the rear seat is always there, then it may be ok. But don't be too surprised if you do like I did, and you wind up throwing it away in a year.
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
  • lzclzc Posts: 483
    The deck stores neatly on the floor, with either the carpet or hard side facing up. However, it doesn't extend all the way to the back seat, leaving a gap of several inches. So I'm not sure the cargo tray will fit neatly on top.
    I've found the deck to be of little use. It adds privacy to what's stored in the cargo area if that's an issue. But, too often, it just gets in the way of loading stuff into the vehicle.
  • dtstofdtstof Posts: 61
    I have both on my 2007. The dual deck cargo tray enables you to add additional cargo to the back while not stacking everything on top of each other. For instance,when grocery shopping, all the paper supplies can go up top. You can keep it folded in half for tall items down below and still have a small shelf up top. It also hides everything in the trunk. It fits on the floor. I have both items and love them.
  • motoguy128motoguy128 Posts: 146
    I find the shelf very useful. It gives you 2 levels for groceries... so you can place the lighter, squishable item on top and heavier items down below. Just stow it on the floor when you dont' need it. It also hides items underneith it too.
    The gap behind the seat is a lot smaller if you recline the rear seats a little ways..
2010 CR-V Cargo Tray + Cargo Shelf — Car Forums at Edmunds.com
