2011 Legacy: Strange Noise from rear of car
tapone1tapone1 Posts: 8
edited August 2014 in Subaru
When turning 90 degrees from a dead stop, there is a noise almost like you are driving over the "rumble" strips on the side of the road. It is not as loud or high pitched as that noise, but low and muffled. My car does it turning in either direction. If I take the same turn at any speed, no noise. Subaru dealer service department says it is just the AWD system and is normal. Is it? Called the salseman who drives a Subaru Impreza and he says his does the same.
  • xwesxxwesx Fairbanks, AlaskaPosts: 9,740
    edited September 2010
    Not normal. Not at all.
    I suspect the bushing on the center driveshaft bearing is bad. Under high torque situations, it is "wobbling." I know it seems odd that something like this would happen to a new car, but this is a molded rubber bushing, so it is possible that it was defective upon molding.
    I would definitely take it to a dealership for a warranty claim. If the problem is what I suspect, it doesn't really hurt anything when it happens, but it will only get worse as time goes on. If it is not that but something else, then it could be causing other damage.
    2008 and 2010 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup
2011 Legacy: Strange Noise from rear of car — Car Forums at Edmunds.com
