2004 Forester: P0301 - P0304, P1447
figsysfigsys Posts: 3
edited September 2014 in Subaru
2004 Forester getting check engine line codes P0301-P0304 and also P1447 every 2 weeks. Car has ~105000 miles.The first four are cylinder misfires; last one is some emmision code. Anyone know what it is and what this can be due to? I have the same problem at 60K (except for P1447) and now it's back.
  • xwesxxwesx Fairbanks, AlaskaPosts: 9,690
    Just curious, what work did you have done at 60,000 after the first event?
    With all four cylinders recording misfires, I have to think it is a fuel or spark issue. If your plugs and/or wires are old, that may be a first place to start. If the car is not running well, it is likely that emissions codes could follow, so I would start with addressing the engine health and see if that clears up the other issue(s).
    2008 and 2010 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup
  • ateixeiraateixeira Posts: 72,587
    Check:
    * fuel filter
    * fuel pump
    * ignition wires
    * spark plugs
    * ignition coil
    If all 4 misfire it can't be a fluke.
2004 Forester: P0301 - P0304, P1447 - Car Forums at Edmunds.com
