Best used truck?
I want to solicit opinions on the best used truck
for the money. My needs are:
- costs less than $5,000
- little to no maintenance required (I am not a
skilled auto mechanic)
- large enough flatbed to carry windsurfing gear
(up to 8'8" long) without sticking out the back
- 4 wheel drive preferred (needs to do ok in
inclement weather)
- weekend usage only (this will be my second
vehicle)
- rides nice (is this even a criteria for owning a
truck?)
Any help would be appreciated!
inclement weather)
vehicle)
truck?)
years 86-88 for $5000 or below, very reliable , easy to work on. Problem areas: Rusty beds in those years, Transmission bearings in 5sp., timing chains in 100k mile area,
Just click on the link for "Used Vehicles" at the top left side of this page. Then, from the list, choose your manufacturer (hint: "FORD"). Then choose the model from the next page, then year. The site will return any information to you that it has pertaining to that model. It will include hot links to recall notices etc. Good luck!
Please Fill out Profile
I may a little bit baised when it comes to trucks
But Ford Rangers are GARBAGE
Suggest you check out the Dodge Dakota
with 3.9 v/6 or 5.2 v/8
THANKS. I FILLED OUT A PROFILE. I CHANGED MY DISCRIPTION FROM DARKWING(DDARTON) TO DARKWING(DARKWING)
Try clicking on the "Used Vehicles" icon, enter the pertinent data and it will take you to the section that includes info on the year/make of the truck you're looking for.
It appears you have your hands full directing people to the right topic areas and the appropriate chapters in the Edmund's New and Used Truck Books for answers to their questions; anyway, I certainly appreciate the hard work you obviously do; and I'll bet I could have placed this note in some other "topic area" discussion.
Michael from Tampa
...mechanical problems???
...psycoram sez GARBAGE???
Should I go the Dakota way???
I'm not fond of recent Chevy S-10's, but I could
be convinced with some +feedback...
...no imports(but I heard Toyota was pretty good)
Help...I need vehicle in next 2-3 weeks...
Thanx.
I JUST BOUGHT A "92" FORD RANGER SUPER CAB 4X4 W/THE 4.0 LT ENGINE. IT HAS 81K (MILEAGE) ON IT AND (KNOCK ON WOOD) IT STILL PURSSS LIKE A KITTEN AND RUNS STRONG. I HAVE A CODE DIAGNOSTIC MACHINE AND THERE ARE NO CODE PROBLEMS WITH IT EITHER, MEANING ALL MECHANICAL ITEMS THAT ARE RAN BY THE COMPUTER ARE WORKING FINE AT THIS TIME. JUST MAKE SURE YOU CHECK OUT WHATEVER VEHICLE YOU BUY VERY GOOD, BECAUSE ALL MAKES AND MODELS HAVE THEIR GOOD VEH'S AND THEIR LEMONS.
My name is Leonard. I am looking for suggestions on what kind of truck would be good for towing a 5th Wheel. Probably 8,000 to 10,000 lbs. Ford, Chevy, Dodge? What size engine would be best? 2WD or 4WD? I am looking for a used truck for under $7,000. Any one have any suggestions? Thanks!
Thanks for any help
PLEASE! BUYERS BEWARE!
Check out all vehicles thoroughly before you buy whether they are new or used. I see everyone advising buyers to have the vehicle checked by a mechanic, well don't forget a good frame shop too! My first "Special Order Truck" came in with hidden damages that were not disclosed. It took my noticing "something doesn't look right" and then investigating it before a replacement was reordered. CHECK IT! CHECK IT! CHECK IT! Good luck shoppers.
The only area of concern should be the E4OD trans.
if it was serviced and not abused it is relatively bulletproof, (I know people who tow over 7,000 lbs with the same combo as mine and have experienced trans. problems and then they blame the E4OD trans., when you try to explain that this combo is not rated for that type of service they just scratch their head and say I figured that it was a big truck and it could tow that kind of weight, DUH!!!) A word to the wise ADD A TRANS. COOLER if it dosen't have one. There is no reason why my truck should not go another 100,000 miles I'm that confident and would buy another one in a minute. Good Luck bcre8iv@yahoo.com
Increase in income: You can afford a nicer vehicle. why not step up?
Change in lifestyle: Don't need a truck bed. You pay someone to deliver stuff or move your stuff.
You want extreme handling and speed: Car or bike only alternative unless you lower the truck and hop it up.
I on the other hand love my 4X4 pickup, chicks love it and my dog loves it.
Think I'll keep it :-)
Later,
greyhnd@geocities.com
Another reason someone might be selling a good vehicle is if their needs change. I bought my truck in Alaska. A little over a year later, my job transferred me to Southern CA. I had a lot more truck than I needed when I was in CA. I held on to it because I liked the truck, but a lot of people likely would have sold it in favor of a more economical vehicle.
goodluck,
Joel
The only way I buy any vehicle is as slightly used as possible but not new. I have run into many reasons that people sell an almost new vehicle. Usually it is because they cant afford it or a divorce or a new kid on the way. The bottom line is just have it checked out. It will have the original warranty and sometimes a transferrable 100,000 mile warranty so the mechanicals don't scare me at all. What I look for is repaired body/ frame damage. I have run into a few that look great, seem to drive fine and I take them to my body shop and find that it should have been totaled from an accident but was fixed because it was so new. What ever the seller tells you is the reason for selling DON'T BELIEVE IT!! Have it checked out!!!
Buying almost new, even a leased one has always saved me thousands from new and I have never been burned. I'm looking for a 96 Range Rover 4.0 SE right now and own a 96 Tacoma 4x4 and an older Rover that I bought slightly used and they have been great! When I see a new model of something I want (like the 96 Rover) I always think how I can't wait for a year or two so I can buy one. Let the guy that always has to buy a new one take the hit (there is no shortage of them).
I have a 96 Chevy C1500 ext cab with 17k miles
I'am selling it , or trading it because I bought a
5th wheel , which it pulls fine but , it wiggles going down the road & I'am afraid I or my wife will wreck it.
JT
know they get so early in Kentucky! best ride in a small truck Ive ever seen Im looking for a replacement.
jd
My 85 dodge ram slant 6 engine has bad
cyl- otherwise auto/ps/full size/cap/217,000
mi/nice condx so will put it in paper as is
soon.. question is...haven't bought looked at
new/used ina long time...reliability is my
prime concern. looking for 1-3 yr old low
miles but i guess my first concern shud be
Toy/Nissan vs ForDodgchev's..
any help greatly appreciated... jim
