Mazda3 High Mileage (2004-2009)
Hi, everyone, I am doing a survey to see how many miles can Mazda 3 get before it dies.
If you can, please report the status of your Mazda3.
1. Year
2. Mileage
3. Auto/Manual Transmission
4. Transmission repaired? If yes, at what mileage? New or rebuilt?
  • 1. 2005
    2. 123550
    3. Auto
    4. No.
    NB: When cold start, the shifting 1st to 2nd gear jerks. Is this the sign of transmission going bad?
  • irguyirguy Posts: 1
    1. 2006
    2. 166,000
    3. Manual Transmission
    4. 3rd issue (slips out of gear) at ~160k, replaced with used trans
    5. Engine noise at 166k, dealer says lifters or timing chain (likely) and advised to replace with used rather than repair (teardown to diagnose ~$1k)
    NOTES: Replacement transmission shifts more smoothly than the original ever did; car has hit redline at least once per day for the past 5+ years and has required no major repairs.
  • jpeng709jpeng709 Posts: 3
    Wow,,, you really have got high millage on it. How much did you pay for used Transmission? It's nice to have Manual Transmission, repairing cost is much lower than auto.
    I just send mine to Mazda dealer, they flashed PCM and transmission fluid. But still feel little shift shock 1st to 2nd gear when its cold, its gets better when it's warmed up. and the dealer quoted me a new transmission for $3.5k. :(
    NO more getting auto transmission on Mazda cars, really like the 3 series, but their transmission really bothers me.
  • phil7890phil7890 Posts: 3
    1. Year 2005
    2. Mileage 161,000
    3. Auto/Manual Transmission Manual 5sp
    4. Transmission repaired? If yes, at what mileage? New or rebuilt? Origianl transmission and clutch; has had four different drivers, two teenagers
  • roadburnerroadburner Posts: 9,033
    1. 2007 Mazdaspeed 3
    2. 103,000
    3. Manual(as it should be)
    4. Absolutely no issues; I run Ford Synthetic Manual Transmission Oil and change it every 30,000 miles.
    Mine: 1995 318ti Club Sport / 2014 M235i / 1999 Wrangler / 1996 Speed Triple Challenge Cup Replica Wife's: 2004 X3 2.5i Son's: 2009 328i
  • jfish5jfish5 Posts: 3
    I am shopping for a used Mazda3. I drove an 06 and the clutch (which had been recently replaced) didn't engage until the very end of it's travel. Does that seem normal. Thanks.
    Same question for you please. Thanks.
    In the case of my Mazdaspeed 3 the clutch pedal engagement height is normal but the engagement itself is very abrupt- not all that progressive. From published tests and drives of other MS3s I've concluded that the "digital" clutch action is just the nature of the beast.
  • p928sp928s Posts: 4
    1. 2007 2.3 s 5-door
    2. 130k
    3. Auto Transmission
    4. Transmission repaired? No, though I get a hard shift between 3rd and 4th when accelerating hard.
    You didn't ask about other issues, but I had alternator failure at 115k miles which disabled the car and required a tow to the shop and $700 repair bill.
    Otherwise a very fun and reliable car with 35 mpg hwy.
  • autonomousautonomous Posts: 1,769
    Care to expand on this failure? Were there any warning signs or recommended service checks by your mechanic? For example, when the car was in service was the alternator ever checked? Also, failed alternators are sometimes due to battery failures or a battery due for replacement. Was this not spotted by the service mechanic ahead of time?
    No warning signs on the alternator failure. I live out in the sticks and do most maint. myself so the car rarely sees a mechanic. I did have battery failure early in the life of the car, but no issues after that. Battery was fine at the time of the failure. It's the same one in there now almost a year later.
    The alternator failure caused a bunch of erratic electrical problems. I first noticed a problem about a mile after leaving work. The tach needle started jumping around and lights on the dash started blinking. Then the antilock/stability control started to malfunction and I had to pull off the road. I thought maybe shutting off the engine would clear things up but it wouldn't re-start. $700 and a year later it's been fine.
    I have alignment issues now. The car is eating tires. Going to take it in for a full alignment this week. Like I said, it doesn't get professional maintenance but neither does my 2005 V8 4runner with similar mileage. The 4runner has been flawless.
    Thanks for your response.
  • 1. 2004
    2. 115,000
    3. Manual
    4. No, but starting to notice a very slight slip in both 3rd and 4th gear; it seems to take a moment for it to actually "get into gear".
    I came on here looking to see prices to replace, and what others may have paid. I LOVE this car, and although I could get a new one, prefer to see about possibly replacing transmission when the time comes...
  • samb6samb6 Posts: 1
    1. 2006
    2. 178,000
    4. Replaced transmission with a used transmission at 176,000 miles. Used transmission was from a 2008 Mazda5 with 30k miles. Transmission with install labor was $1,100. Dealer quoted me $3,000 to replace transmission with a rebuilt unit. Per the owner's manual, I never changed the transmission fluid. My new mechanic recommends changing every 24 months/30,000 miles.
  • 1. 2004
    2. 239,000
    3. Auto
    4. Original with one flush at 120k
    Cold 1-2 is a little jerky but otherwise shifts fine
    Keep your mass airflow sensor clean (all 4 wires)
Mazda3 High Mileage (2004-2009) — Car Forums at Edmunds.com
