2003 ford ranger v6 3.0 100,000 miles bucking/loss of power out
maninblack12
Member Posts: 1
in Ford
I got a 2003 ford ranger with 100,000 miles. V6 3.0L with running issues. The truck will drive at lower speeds (45 and below) just fine. When you go to pass someone, get on the interstate or just floor the pedal it bucks and cuts out like its cutting the fuel. I changed the fuel filter hopeing for the obvious but not luck. After changeing the filter it ran fine for a block when I floord it but then started bucking after that. It has no codes and the fuel pressure seems a little high from a freind who checked it. I was thinking possibably the fuel pump or the fuel pressure regulator but dont know alot about these trucks being as its my first ford. Anyone have any suggestions?
Try plugs and plug wires. Had same problem, and I pull a boat with my 03 fx4 and I can't have a loss of power. Drove it 2-3,000 miles since and no problems!
