2012 TL Tech FWD "1500 RPM HESITATION PROBLEM FIX ."
This Hesitation Problem @ 1500 RPM will drive you Nuts & is A major safety
issue when you're trying to make a Left turn with oncoming traffic or when
changing lanes... as the car Hesitates... GOES NOWHERE UP TO 3-SECONDS !
Dealer will tell you " they can NOT find ANY problems because It Does NOT
throw-on Check Engine Light or any Codes with an in-dash monitor . "
THE PROBLEM = APP / THROTTLE SENSOR .... is a 2-part sensor.... THAT
NEEDS TO BE REPLACED ! If only 1-part of the sensor is bad... IT WILL NOT
THROW-ON CHECK ENGINE LIGHT OR CODES. The part costs $ 144 retail /
$ 44 wholesale .
