stalling subaru legacy 2004
My Subaru Legacy 2,0 2004 often will stall in the morning . The rpm will dropp to zero and sometimes it will get back to 1500 rpm and sometimed it will die . When it dies it is hard to get started again byt when it starts it smells gas ... The Map sensor i new, new sparkplugs, new air filter .
CAn it be the 02 sensor before the cat ?
  • I forgot. There are no codes in the ecu and the engine light is not on
  • ateixeiraateixeira Posts: 72,587
    Spark or fuel....
    Could be the ignition coil, or the wires (did 04s still have em?).
    No MIL? Strange.
    I might also try the fuel filter since it's cheap.
  • Dont think its the fuel filter , the engine response is normal.... Yes, there are are coil and wires .. When the engine has gone for a few minutes its runs alright
  • xwesxxwesx Fairbanks, AlaskaPosts: 9,940
    I'd have a look at the knock sensor. My '96 ran terrible when it was cold for a couple of weeks, but fine (mostly) when it was warm. I did have a CEL, but it was for something seemingly unrelated, along with a code indicating an intermittent problem with the camshaft sensor. I replaced that sensor, the knock sensor, and the crankshaft sensor simultaneously, and it ran like a top after that. As a bonus, a nagging no-start-after-warm issue I had suffered with for years was suddenly solved as well!
    I probably didn't need to replace the crankshaft sensor, but all's well that ends well. :P
    When the car is cold, it runs the idle off a map rather than adjusting fuel/air ratio based on oxygen sensor feedback, etc. So, I doubt it is your oxygen sensors. Rather, in order to maintain idle, it advances/retards timing based on knock sensor feedback.
    2013 Volkwagen Passat TDI, 2008 and 2010 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup
  • I have no fault codes in the ecu.
    I have chanched the map sensor ...
    A tip was to reset the throttlebody during to disconect the + and - cable from the battery and put them together for about 15 min .
    I tried to do that 2 days ago and so far so good , no problems left .
    Lets se if it holding that way
stalling subaru legacy 2004 — Car Forums at
