1998 Pontiac Grand Prix SE code scanner failure
battlinjack
Member Posts: 2
in Pontiac
My 1998 Pontaic Grand Prix SE 3.1 V6 has failed emissions twice now. I replaced the EGR valve, cam sensor and want to check the code to see if anything else pops, but the code scanner (Mac Tools 9040 Global OBD II Code Scanner #ET9040) won't power up. The scanner works fine on other cars, just not mine. Is there someway I can get it to work?
I'm not big on newer computer cars. My specialty is old American muscle cars and this stuff is just irritating.
First check all fuses.
then check the data port for loose or backed out or corroded pins; also check the connection behind the data port.
On most cars if you insert a slider over pins 16 and 5 (you can buy these sliders at Radio Shack), you can then test for 12V and for a bad ground (16 should read 12V and 5 should supply the ground).
