Grand Marquis slipping into gear
I have a 2005 Grand Marquis that has trouble getting into gear. When I shift into reverse, it takes a couple seconds to get into gear. Also when I'm moving forward it sometimes seems to slip when shifting gears.
  • It your fluid level accurate/is it clean?
    I usually wouldn't rec additives, but many have had success with these Ford trannys using Lucas Transmission Fix. If I had this problem and my fluid was good and properly full I'd try the Lucas.
  • euphoniumeuphonium Great Northwest, West of the Cascades.Posts: 3,425
    Change the fluid to Mercon V or similar semi synthetic. Replace the filter while in there and if that doesn't improve the performance, then maybe try the Lucas which is very thick & will develop your patience while pouring.
  • The fluid levels are accurate and as far as I know clean. The transmission fluid was a dark reddish color which I thought was a good thing.
    I can try to change the filter and transmission fluid, and the Lucas as well-
Grand Marquis slipping into gear - Car Forums at Edmunds.com
