Ask Connor at The Tire Rack
SylviaSylvia Posts: 1,636
Connor from The Tire Rack is here to answer your specific tire questions.
If you want to have general tire discussions, please use the Tire, tires, tires discussion. This should make for an easier Q&A process.
Enjoy!
«13456743
  • micwebmicweb Posts: 1,617
    Is there a 205 aspect tire in 15" wheel size to replace the stock 185x60x15 tires on the stock aluminum wheels, or is there a clearance problem? Your website only indicates 195x55 as an alternative for the 15" wheels.
  • goldstongoldston Posts: 110
    Hello Connor,
    Thank you for taking the time and being so helpful to all of us.
    As stated in the header, I'm considering possible tires for my Toyota Highlander 2WD Limited. The vehicle is only used for city / highway driving here in Phoenix Az.
    1. Geolandar H/T-S G051
    2. Michelin Cross Terrain SUV
    3. Goodyear Fortera HL Edition
    4. Michelin LTX M/S
    I realize that is maybe to broad a field and that I may need to do some narrowing down from 4 to 2 choices to help you. But, any thoughts or advise is greatly appreciated.
    Also, price is not a problem, tires cost what they cost. My life is worth more than saving a few bucks.
    Best regards,
    Philip
  • billyperksbillyperks Posts: 449
    What's a good set of tires for an Acura TL TYPE S?
    Price matters to me-I ned something reasonable.
  • frag235frag235 Posts: 81
    Hi Conner....welcome to the board! What would be a good replacement tire for a current model Accord sedan 4-cylinder other then Michelin? H/V rated Bridgestone Turenza's get good reviews on your site and you mentioned a Continental tire? The size is 205/60-16. I'm looking for good handling (dry and wet) and a quiet ride.
  • bolucaboluca Pittsboro, NCPosts: 25
    My wife drives a 2000 Infiniti G20 and will soon need new tires.
    The size is 195/65-15, H rated.
    It has BF Goodrich Touring tires on it now but I have always like Michelin. After reading some reviews I was leaning toward the Bridgestone Turanza LS-H or the Potenza RE950.
    We don't need a high performance tire.
    I want something quite, last at least 40,000 miles, good handling, and good in the rain. We might get some snow 3 days a year.
    What do you recommend?
  • Out of the four tires you have listed i would recommend them in the following order:
    1. 225/70/16 Michelin Cross Terrain SUV -- 135.00 each
    2. 225/70/16 Geolandar H/T-S G051 -- 77.00 each
    3. 225/70/16 Goodyear Fortera HL Edition -- not available in this size
    4. 225/70/16 Michelin LTX M/S -- 119.00 each
    The Michelin Cross Terrain will offer the best overall handling and ride quality. They are also rated at 65,000 miles so you will have them for some time. The Yokohama Geolander HT-S are also a very good tire. the down side in comparison to the cross terrains is that they will be slightly noisier and are rated at 55,000 miles. all four are good tires but i would rank them in the order as above.
    connor@tirerack.com
    Tire & Wheel Specialist
    The Tire Rack
    877-522-8473 ext 269
  • kyfdxkyfdx Posts: 47,065
    I have Turanza LS-H on my '92 Legend.. size 205/50-15. I don't have a lot of miles on them yet, but dry and wet handling are great, good ride, and quiet. I didn't get it out in the snow this year, so I couldn't comment on that. I do recommend them.
    regards,
    kyfdx
    Prices Paid, Lease Questions, SUVs
  • badgerfanbadgerfan Posts: 1,565
    Thanks for your previous recommendation for inexpensive replacement tires my son's 92 Sable.
    Now on to another subject. My 2000 Taurus SES has the OEM Continentals Touring Contact AS on it and I am at about 37K miles. I just noticed the rubber sidewalls developing a ring of fine cracks just about 1/2" beyond the rim. They still have a decent amount of tread left. Does Tirerack have any experience with this? Please note I never let my tires run with low pressure. I check them regularly and run them 2-4 PSI above Ford's recommendation.
    Do you think this could be a manufacturing defect?
    Any chance Continental will honor any pro-rated warranty? I checked their web site and they warranty weather cracking on OEM tires for 4 years, and they also have a 72 month pro-rated warranty for other defects. I am still below both as I bought the car new in September 2000
  • Since i don't see what year your vehicle is i just assumed it was a 2003 Acura TL-S with a 215/50/17. if you are looking for a good performacne tire at an economic price i would recommend the Continental Extreme contact (95.00 each) first and as a second recommendation i would suggest the Sumitomo HTR+ (79.00 each). Both are good tires but the Continental will have a little better tread life and will be a little quieter.
    connor@tirerack.com
    The Tire Rack
    Conner,
    Thank you very much. You hit it exactly right by putting them in order and then stating about the noise issue with the Geolandar. Since this is my wife's vehicle a quite tire is high on her importance list.
    Best Regards,
    Philip
  • I would suggest trying the 205/60/16 Bridgestone Turanza LS-H. they are an outstanding tire with a great ride quality. the vehicle only requires an "S" speed rating but the "H" speed rating will offer a little better ride quality. they are currently priced at 104.00 each. the only Continental i would recommend would be the Continental Premier Contact which are a good tire but not great. they are currently priced at 79.00 each. Also the Bridgestone will have better wet traction and handling as well as better snow traction than the Continental.
    connor@tirerack.com
    The Tire Rack
  • I think the Bridgestone Turanza is an excellent tire (see previous post) and believe you would be very happy with this tire. you could use a P205/60HR16 Michelin Energy MXV4 PLUS which is currently priced at 117.00 each. You would end up paying a little more for a tire that i would place second to the Bridgestone Turanza LS-H. The Bridgestone is rated at 50,000 miles with a 30 day ride quality guarantee. if your not happy with the tires in the first 30 days you can retrun the for a full credit towards another set of four tires in the same size.
    connor@tirerack.com
    The Tire Rack
    I'll definetly check out the Bridgestones....they've gotten a lot of positive reviews on your site too.
  • capriracercapriracer Somewhere in the USPosts: 838
    It is common for cracks to show up late in a tire's life. In fact it is a good thing as it gives a fairly benign indication of when to remove your tires for reasons other than treadwear.
    As far as the warranty goes, normally this would be an adjustable condition and the tires would be prorated, but you would have to pay for the mounting and balancing, so the net effect is a bit more expense than you may think. And considering how inconsequential this condition is, I'd recommend you monitor the situation and see if it gets bad enough to worry about. I'm going to guess you'll wear the tires out before the cracks become large.
    BTW, I have never been able to trace any sort of tire failure to SW cracks and I look at tire failures for a living.
    Hope this helps.
  • topspin628topspin628 Posts: 373
    I am currently considering either of these new cars and wanted to know if the SC can be driven year round in the North East with the proper tires. It comes with standard run flat summer tires. What are my options and cost factors.
    Also, for the LS with the all seasons, will they suffice for year round.
  • jc1973jc1973 Posts: 63
    hello i have a 90 ford hightop camper van that will need new tires im looking for something decent not to expensive though i only drive this van 5000 miles a year tire size is 2357515 but currently has 2457015 on it is the oe size good or should i upgrade any info much appriacieted
  • edspider1edspider1 Posts: 195
    The LS forum seems to like the Tuaranza. My number one requirements in order of importance are all season, lowest noise, softest ride. What would your recommendation be?
  • mudflatmudflat Posts: 47
    I have a Mazda Protege5. The stock tires are Dunlop P5000M. I'd like to replace them with ones a little quieter and smoother riding but I don't want to compromise handling any more than I have to. We don't have snow here, but it rains a lot both summer and winter.
    What do you recommend to best meet the above criteria, and what comes closest to matching the Dunlops?
  • bigdadi118bigdadi118 Posts: 1,207
    OEM Dunlop tires on 16" alloy do make noise and kind of bumpy ride. Below is a post from the MPV forum. Is this the case as described and what kind of tire is recommeded in case of replacement?
    #7387 of 7387 tomj5 by bottgers May 09, 2004 (6:00 pm)
    Either you drive on some really smooth roads, or you're just used to a choppy riding vehicle because I certainly wouldn't describe the ride of our PeeVee as "fine." I would describe it more like bone jarring. The reason I believe it's the tires causing the choppy ride is because the suspension seems to handle the larger bumps, but it's the smaller ones, ones that don't get the suspension too involved that it seems to have trouble with. Bumps like the little seams between the pavement slabs. These types of bumps normally get soaked up by the tires......that is tires with sidewalls that aren't too stiff. I've noticed this type of a ride in any vehicle I've ever been in that's had "H" or higher speed rated tires. I'd be willing to bet a pay check that replacing the OEM "H" rated tires with a good set of all season touring tires would make a night and day difference in smoothing out the ride. Of course, you're going to give up a bit of the handling, but I don't spend much time canyon carving with ours. I'd rather have the smooth ride.
  • corvettecorvette United StatesPosts: 4,889
    Is the tread wear rating of 500 conservative, or does the light weight of the truck cause them to wear slowly? I seem to read a lot of S-10/Sonoma owners hitting the 100,000 mile mark out of these tires if they aren't destroyed by road hazards.
  • jetjet Posts: 1
    stock size is 215/55/16, will 225/55/16 fit? I like a smoth quiet ride but with good steering response for street driving. have been somewhat dissapointed with the stock mxv's with poor traction in wet I use 38 lbs. front 32 lbs rear with improved handling and even wear. I have been considering kuhmo ecsta kh11's or pirelli P-7's if the larger size fits I would consider yokohama avs db s2 also concidering the sumitomo srixon4 or bfg traction ta's any suggestions for a civilized tire?
    Thanks for your input. I will keep an eye on the sidewall cracks. I will probably drive them another 8-10K miles and then change them out. I don't particularly want to go with Continentals again anyway, and would be forced to if I got any warranty coverage. The Conti's are not the greatest for wet traction, so I will likely go with something else for replacements in a year.
    You are absoulutely correct-it is 2003 tls.
    I am hearing good reviews about the Falken ZE -512 ZIEX, what is your take on that tire?
  • I would need to know which year of LS430 and SC430 you are referring to? If you could let me know i would be more than happy to look at the possiblities for your cars. most people think that all cars with the same name plate are always the same, but i like to check to be sure before i just guess at a year.
    connor@tirerack.com
    The Tire Rack
  • If you are asking for specific infor mation about your vehicle please include the exact year, make, model, and package. The exact model can make a pretty big difference considering they could all have different suspension clearance, different brake component clearance, and different fitment specifications. For some some vehicles i can make educated assumptions about what year it was or the originall equipment that came on a car. but most vehicle made in todays market have several original equipment tire sizes and models as well as different suspension packages that can change the clearance on the tires. I would simply rather be able to guarantee the infomation i am giving you rather than guess at the exact model of vehicle.
    Also, i am not in the office on saturday or sunday. if you direct a post towards me you may not see a reply until late monday or tuesday but i will get back to you. If you require a more immediate response please email me directly at connor@tirerack.com or give me a call at 800-428-8355 X269.
    connor@tirerack.com
    The Tire Rack
  • dtate99dtate99 Posts: 122
    Connor, how would you rank these three tires for my car (cost not being a factor)? My second set of Bridgestone Turanza EL42s are as bad or worse than the originals as far as flatspotting and slightly rough ride.
    A) Michelin Pilot Sport A/S
    B) Falken ZE-512
    C) Toyo Proxes4
    All are in the appropriate size (235/45/R17).
  • shiposhipo Posts: 9,152
    Connor, while your opining on 235/45 R17s, I thought I'd add to the mix. I have a 2002 530i SP that came with Michelin Pilot Primacy tires in the aforementioned size . Other than the noise that they are starting to eminate, they seem to be more than adequate for my current driving needs. After reviewing the various options on TireRack.com, I have narrowed it down to the following three:
    1) Goodyear Eagle F1 GS-D3
    2) Bridgestone Potenza S-03 Pole Position
    3) Michelin Pilot Sport
    4) Michelin Pilot Sport A/S
    Did I miss any?
    What might your suggestion be?
    Best Regards,
    Shipo
  • toneetouchtoneetouch Posts: 60
    hello,
    i have a sidewall bulge on the front left tire of my p5's DUNLOP SP SPORT 5000 M Size:195/50WR16, so the tire needs to be replaced (18,000 miles). are there any drawbacks to replacing that one tire with a KUMHO ECSTA ASX Size:195/50VR16 ($40 cheaper than replacing with an identical dunlop on tirerack.com)? thanks.
    ant
  • eman5eman5 Posts: 110
  • Because the wieght class of the van was not listed i am basing the information i am giving on an 1990 Ford E150. i would recommend using at least a "C" load range tire due to the fact this is a camper top van. the camper tops additional wieght will cause this van to have a higher center of gravity than a standard van. the stiffer side wall of the "C" load range will make the vehicle handle a little better on the road. i would recommend one of the following two tires. the Firestone tends to be a little quieter but the michelin will last longer.
    LT235/75R15 Firestone Destination LE - "C" - 72.00 each
    LT235/75R15 Michelin LTX MS - "C" - 111.00 each
    connor@tirerack.com
    The Tire Rack
«13456743
Ask Connor at The Tire Rack — Car Forums at Edmunds.com
