Toyota Corolla Fog Lights
echosierraechosierra Posts: 3
edited June 2014 in Toyota
Anyone know where I can get a replacement fog light for a good price? I've been looking online and so far the cheapest i can find is $120 for one side or $85 for an after-market kit for both left and right sides. I only need the passenger side cause I hit a deer. Luckily that was the only damage. It's not broken just doesn't work anymore. :(
  • sr45sr45 Posts: 144
    I to want the fog lamps for my LE, 06 model. Even the darn dealership does not have them on the computer or book. Seems odd that if a S model had damage to the fog lamps, they would have a cost for a replacement on the computer, but do not. Trying to find where I can get two lamps to have the dealer put on....Do you know where ?
  • You can get aftermarket clear lens fog lights on ebay both sides and kit for like $85. I don't know how good they are but maybe you can find some feedback on ebay if anyone has purchased them.
    Thanks for the reply echosierra regarding the fog lamps. I will wait until the vehicle is on the dealers lot than try to find one that fits.
  • I just bought a used 2004 corolla s model. No owners manual. This may sound stupid but what the heck. How do you turn on the fog lamps?
  • beernutbeernut Posts: 329
    Its a twistie-ring on the end of the left stalk, next to the headlights.
  • use the same switch for your lights, there is a small piece that turns at the end of the main light switch on the left side of your steering wheel..........
  • lamonlamon Posts: 1
    I just bought a pair of fog lamps for my corolla , the cam with a harness that connect to the lamps , on that harness is a ground strap\and what appears to be a 12 volt lead. a second harness came that attaches to the switch that sits in where the other switches go ,a relay and a connector that i have not found the location for. if any one has purchased a kit can u please help me.
  • Hi,
    I bought a set off of ebay and just ordered the fog lamp switch and relay for my '05 LE. I will use the existing wiring harness 'cause its easier. I'll tell you how to do it and give you part numbers if you want or help you figure out how to make the extra wiring harness work after I get my car done.
  • I also bought fog lights off ebay for my LE. I do not have the lights yet, but I will be getting them in a few days. I was wondering if you could tell me how to do it. I have never done anything like this before. Thanks.
  • Hi Chalupa,
    I will use the existing wiring harness for my car. It will cost, $116.88 for the turn signal/ fog lamp switch, and $44.97 for the relay. But the instal will look stock and work every time. If you use the wiring harness supplied with the ebay Fog Lamps you'll have to find a place to mount the relay,connect a chassis ground and instrument illumination wire in side the cabin, and connect battery power, battery ground in the engine bay, route and secure the harness. That's a lotta work. The other way with Toyota parts from is easier.
  • Thanks a lot mlewandowski. I used the kit I got from ebay and installed the lights. It took some time hooking them up, but they work great.
  • Hi all. I just bought a 2006 Corolla and would like to install fog lamps. Looks like I can buy them on Ebay, but I have no previous car modification experience. I am reasonably competent with things mechanical, electrical, and electronic (computers) - what skills would I need to install them? Are there guides available anywhere?
    Any advice would be appreciated.
  • yos25yos25 Posts: 1
    I just got the fog lights from ebay. I see my car come wired from factory. I was wondering if the only thing I have to do is connect the switch and the relay in the cabin... Can anyone help me please...???
    I looked for a place to connect the switch in the cabin and I can't find anything... Please help.
    How did you do it mlewandowski.
  • Hi, the fog lamp kit sold on ebay is designed for a 2003 Camry. The lights fit the Corolla and connect to the factory wiring harness. With the additional purchase of the factory relay and turn signal/fog lamp switch, ( the lights will work along with the auto-headlamp function. That is the easiest way to add the lamps. If you need more information let me know.
  • Hi, I used this procedure to install the ebay fog lamps on a 2005 Corolla LE.
    1) Push out the UGLY black fog lamp covers and discard.
    (Sell these things on ebay.)
    2) Install the really great looking Fog Lamps that Toyota won't sell as an option. Remove the Phillips screw from the back of the new lamps, press the white plastic retainer into the small slot from behind. (Two small clips hold it in place.) Hook the gray plastic tab on the Lamp into the outboard slot and swing the Lamp assembly into position, Move the retainer as needed until the screw will mate and hold the Lamp. (Use a stubby screwdriver 'cause you don't have much room.)
    3) Connect the Lamps to the existing wiring harness. Look for an oval shaped black connector taped up against the inside wall.
    4) Repeat for the other side.
    5) Install the Fog Lamp Relay, (Part Number 90080-87026.) in the under hood fuse box. (Lower right side of the panel.)
    6) Replace the turn signal switch with the Fog Lamp/Turn Signal Switch, (Part Number 84140-02200.) Tilt the steering wheel down, remove three Phillips screws from the plastic steering wheel cover. (One brass screw is just to the right of the steering wheel tilt adjust lever, the other two are black and may be hidden by the steering wheel, swing it from side to side while looking at the cover thru the steering wheel, you'll find them.) Pull down on the plastic cover to separate and remove the lower half and push up and to the right to remove the upper half. Use the tip of a screwdriver blade to depress the black plastic retaining tab on the turn signal switch, remove switch and disconnect the white wiring harness. Install the new Fog Lamp switch, (Just line up the tabs with the metal bracket and push till it seats.) reconnect the wiring harness. Test you work. Replace the steering wheel covers, top first, This is the only part that is not a lot of fun, but it will snap back into place. Replace the steering column cover screws,
    that's it. The Lamps will work every time and look like a factory option.
    "Live long, and prosper"
  • kliongkliong Posts: 1
    i also bought fog lamps from ebay unfortunately my corolla ce doesn't come with wiring harness, so i had to buy the after market foglamp, relay switch and wiring harness. i tried installing it with the supplied harness but it doesnt work!!! PLS HELP.
    on the lighting harness, I connected the red to red batt terminal; black to black batt terminal; blue to blue switch harness; and black ground to a ground on the chassis and it doesn't work nor does the light on the switch light up, there is still one green wire which i am not sure where it goes too, it hasn't been stripped off its cable shield.
    any help will be well appreciated
  • What year is your CE? I'm just curious b/c I'm planning on installing fog lamps in my 06 CE and was hoping it wouldn't be too difficult.
  • doulosdoulos Posts: 5
    I just installed fog lamps on my 06 LE using the superb instructions from mlewandowski (#225). The whole process took about 40 minutes and was very easy.
    I used the Vertex Racing fog lamps and the Toyota light switch that mounts on the steering column, but I didn't use the Toyota relay. AutoZone had an equivalent relay for 1/3 the price. Look for part #41-5154.
    Since the LE is already wired for the fog lamps it was a matter of attaching these three pieces (lights, switch, relay) and now it's factory clean.
    I can't tell you what an improvement the new lights are over those stock black plastic covers.
    Thanks mlewandowski!
    If the CE is pre-wired for the lights like the LE is, it's a piece of cake (assuming you're buying the Toyota light stalk and not using the switch that comes with the fog lights).
    You can tell if the CE is pre-wired by looking up under the car behind where the fog lights go for the unused oval plug. It should be taped to the frame nearby. You'll also see an empty FOG relay position in the fuse box in the engine compartment.
    If the CE isn't pre-wired, then you'll have to use the aftermarket harness, relay, and switch that comes with the fog lights. More hassle, but it's not rocket science.
  • yomkiyomki Posts: 3
    Hi, I also have an LE corolla 2005 model and bought a fog lamp from ebay, I tried and checked all information from mlewandowski posting, but there seems to be some differences. The harnes I found don't match the bulb jack. And on the fuse box, there is a place for the fog relay but there is not wires connected to it. Do you think I found the wrong harness? Please advice.
  • Thank you very much for your instructions. My installation was flawless. I do have a question, though - I've read that the relay can be modified to allow the fog lamps to be on with high beams. I drive on some lonely dark roads and would like to have that lighting combination (for critters, if nothing else). Does anyone know how to do this? I saw instructions for doing it on a Boxster on the web somewhere, and it involved soldering a piece of wire between two of the relay's posts. Which two and would that work on a Corolla?
    Hi. me and my brother in law installed ebay aftermarket fog light on my 2005 corolla LE. We used the wire harness that came with the box since the harness that we found in my LE doesn't match the 9006 bulb (I really don't know why, and that's the only available harness I found in my car). With the wire harness that came with the box, there is a green wire that we connect to a powered wire (example is the outlet where you charge your cellphones). What he did, he attached the green wire on my alarm system power wire. So now, I can turn all my light at the same time. :)
  • I purchased the Vertex fog lights and harness for my 2004 Corolla. If I use the supplied harness, where does it plug into the fuse block inside the dash for power? I wish I had wiring instructions, but none came with the kit.
  • roias4roias4 Posts: 2
    I just installed the original fog lamps on the 2005 corolla ce, besides the fog lamp relay do i need anything else to make it work?
    help pls
    if i'm installing the original fog lights on a corolla ce 2005 besides the fog lap relay on the fuse box what else do i need.
    pls help
  • I have purchased a 2006 Corolla LE and am going to use the same procedure you used. I have a couple questions before I get into this.
    1. Do you have to remove the covers underneath the vehicle to gain access to the Fog light installation area? It seems that is the only to get to them.
    2. Do you need to disable the airbag system when installing the new Fog Lamp Turn signal switch.
  • dreyfusdreyfus Posts: 24
    No, you don't need to remove anything under the vehicle. I was able to see and reach the connectors from underneath without a problem. They're taped to the car just behind where the fog lamps are installed. Of course the lights themselves just screw in from the front.
    No, you don't need to do anything with the airbag. Just remove the screws holding the upper and lower steering column cowlings and wiggle them off, then the screw holding the turn signal switch. It comes right out. Unplug it, plug in the new one, and then reverse the process.
    It really is easy. Good luck.
  • Thanks for the info dreyfus.
  • I am getting rady to install all this good stuff (Fof Lights) on my 2006 Corolla LE but I have run into a couple of problems which makes my installation difficult, at least difficult for me.
    1. There is no wiring where the Fog relay goes in the relay box.
    2. There is no wiring to the 15 amp fog fuse holder in the relay box.
    3. So I am not so sure that the new Light switch will have the necessary wiring to it to operate the Fog lamps.
    4. So far haven't been able to find existing wiring to the fog lamp area.
    Appreciate any assistance.
    Thanks Richeyrob
  • thekingtheking Posts: 107
    I sell Toyota........Let dealer will have it under your 36k,36 month warranty...Sure install prices are high but I have seen unhappy customers in our service department who screwed up installation and we would not cover repair under warranty ! A dealer makes statements like that and a customer figures they are trying to get bucks on the install...You spent a lot for the vehicle...let a trained service rep who knows your car do the install !!!
Toyota Corolla Fog Lights — Car Forums at
