Chevrolet Malibu Maxx Interior and Passenger Comfort Concerns
kurtamaxxxguykurtamaxxxguy Posts: 1,794
edited October 2014 in Chevrolet
Chevrolet trim can be "snapped back" into position if you press it in the right spot.
I've run across loose trim in several Maxxes and it's often because the trim mounted fastener simply wasn't pushed into the metal chassis mount hole underneath the trim.
However if the fastener is missing or damaged then the dealer will have to get involved.
Also, in the Maxx, you may find you get really loud squeaks or buzzes from the hatch trim itself. That's because the hatch trim fasteners squeak against the aluminum the hatch is made of. Only way to fix this (that I know of) is to remove the trim, put heavy fiberglass or other tape over the fasteners (preventing metal-metal contact), and then reassemble the trim to the hatch.
«1345
  • ..I mentioned my memory was hazy on this! ;)
    You are right redmaxx...the center trim comes off first. It basically pulls straight off (there's either 3 or 4 plug-style fasteners).
    As for that fusebox door, first step is to press in on the round depression of the panel on the left rear side of the hatch compartment (the one just over the left webbed cubbyhole). That will make the trim hatch pop open and down. Once inside, the fuse box is visible and that can be opened by the other instructions posted here earlier.
  • The vents for the rear passenger area work best when using the fan, and if you also close or partially close the vents for the front passenger area.
  • Take it in. They have had a problem with those. I broke mine, as well as the pull-out visor on the skylight, on the first day I had my '05 and they replaced all for free. They said they have had alot of problems with those parts. At least one other maxx was in for similar parts.
  • maddmaxxmaddmaxx Posts: 81
    e2helper,
    Is the climate control on a '04 Maxx LS interchangeable with the automatic climate control? I guess the LS is somewhat automatic since it turns on the a/c compressor with the defroster, which made me wonder if they were interchangeable.
  • e2helpere2helper Posts: 1,002
    Nope - the automatic climate control in the LT and the standard system in other models are quite a bit different.
    If you want details I could provide but likely that answers your question
  • paopao Posts: 1,867
    Kurt..have you had experience removing the interior trim on the rear hatch..Im going to have to access the CHMSL to replace it....it seems simple enough..the light has two guide posts and one clip to snap it in place..however....one must remove the top interior trim to access it.....appears its in three pieces.....any suggestions for unsnapping it???
  • kurtamaxxxguykurtamaxxxguy Posts: 1,794
    it's been a while, pao, but my memory suggests;
    first remove the side trim pieces (they are held on by "clamp fasteners", and can be pulled loose by pulling them away from the metal and towards the center hatch.)., then pull the top trim straight away from the metal (several metal "prong" fasteners hold this one on).
    when removing side trim, be careful to avoid damaging the rear defrost wires and window grid.
    thanks will look at it more closely tonight...I dont recall side trim pieces...just three panels.....but hey...Im old....so will check tonight....will let you know of my progress
  • redmaxxredmaxx Posts: 627
    Kurt, on my Maxx its the top trim that sits on top. If I were to remove the sides first it would pull the top out with it.
    noticed the same when i got home last night..didnt actually pull it off..Im hoping that will give me access to teh CHMSL......but we will see..have the new one in from gmparts direct....simple plug in design with a metal clip to hold it in place....so looks easy enough if I can get to it....will see this weekend...
  • I have read on other forums that Maxx owner's are having problems with the skylight shades popping out of the holders. I seem to be having the opposite problem...they're stuck! When I put my finger into the little hole on the outside of the shade, nothing happens, I can't even feel anything to grap ahold of! My user manual says nothing of how to open the shades either! Help!
    grasp the shade tab (little dangly tab just below leading edge of the shade), and push it up and towards the side of the trim where the shade is latched to. The shade should then release itself (will pop up slightly), allowing you to gently roll it back into its center wind chamber.
    The fix for keeping the shades latched to the trim tends to make the shades a little harder to unhook from the trim.
    well after looking things over...the top trim panel came off with a stiff pull in the center of the panel piece...exposing the wiring for the rear windo defroster and for the CHMSL...then two access holes....again..some looking over to discover the CHMSL is held in place with two hex fasters that screw onto the plastic posts of the CHMSL......getting those off...being careful not to drop them in the hollow frame of the hatch...the CHMSL falls out....disconnecting it...and attaching the connector....and bang....CHMSL working again!!!!!..inserting it back into the mount..using the same hex fastners....and tighten them both down...the CHMSL is back in place..then with a letter opener...I gently slid it along the both of the CHMSL to raise the rubber seal over the bottom edge of it again...and fixed....to a total of $36 in parts for the CHMSL..from gmpartsdirect..........thanks for everyones help
  • maxx4memaxx4me Posts: 1,340
    pao, I have a gas grill that needs puting together :P
  • lcw1lcw1 Posts: 36
    Dang the cheap plastic
    I drove a full size Chevy van for years and have no complaints since I never had any real problems. I normally get a new one after 150,000 miles or so.
    Because of the gas price I decided to downsize and was very excited about the Maxx after reading the forum. I found a 2005 with only 15,000 miles and decided to give it a look. The car looked terrific on the outside but when I decided to lower the back seats the plastic lever broke instantly. Granted grace is not my middle name but for a one year old car you would think it would stand a gentle push. Needless to say it was disheartening and I couldn’t convince myself to take the car for a test drive. Chevy might have saved $5 per car to install descent knobs and levers and in the process gain more customers. My question is did anybody experience problems with the interior and how did it affect their opinion of the car.
    when delivered my vehicle had a broken rear center armrest and cupholder unit. Yers Truly fixed it by a generous application of goop and slamming it back together (dealer service at time couldn't change a lightbulb).
    There have been dome and seat headrest rattles (others have had these). Fixable by gluing plastic to metal holders.
    Some mags report plastic flashing all over the place. Who knows where they found it...I did see a little on a couple places of the central console, but not that bad.
    I've never had a seat level break. Front ones are not all that sturdy, though.
  • hgr3inokhgr3inok Posts: 28
    We had to replace the right rear seat release lever on our 2004 after 7 months/7000 miles. And I expect we will have to replace it again at some point. For us, that's a fairly minor annoyance for a vehicle that is so versatile, comfortable and inexpensive to operate.
  • estrauss11estrauss11 Posts: 5
    I, had the Front Passenger rear plastic cover retainer repleaced, due to the cover popping off, and after six months I had to have the right rear seat lever replaced, but it was only the handle. The service tech, I talked to was saying that whole lever assembly might need to be tweaked. I think that some of the Maxx's had a problem with the rear seats.
  • maxxindmaxxind Posts: 22
    I'm new to this forum but I've had my '05 Maxx for about 15 months and 31,000 miles. I second the opinion Buffalonickel: The Maxx compares very favorably to many other makes of cars, both imported and domestic. In the miles I've driven (about 80 percent highway and 20 percent city) I've averaged close to 30 mpg overall, and have had nothing at all go wrong with the car. I've changed the oil myself when the oil life monitor has called for it (using Mobil 1) and had the tires rotated once.
    The power is impressive. I think the Maxx SS is a cool car, but honestly I don't need any more power than the regular one has. It passes effortlessly on two lane roads.
    One interesting thing I've noticed that maybe some other owners might be able to shed some light on: About a month after I got my Maxx a friend saw it, liked it, and got one too. His is also an '05, but what's interesting is he gets a little better mileage than I do, but his car does not feel quite as powerful as mine. I wonder if they have the computers programmed differently on some of them, because it just feels like mine runs a little richer than his.
    I have no intention of having mine re-programmed or anything like that, because I believe, "If it ain't broke, don't break it," and to me the compromise between economy and power on my Maxx is perfect.
    One other question for other Maxx owners: Do you find that in hot weather (90+) you just about have to run the a/c in recirculate mode to get the car cool enough? This is what I find. Also, it seems that the a/c system automatically throttles itself back when the headlights come on. Does anyone else notice this? I figure maybe it's an energy saving feature to limit a/c compressor operation when it's dark out and less cooling is needed.
    I haven't noticed the light/AC relationship issue. However, every car's AC needs to be run on recirculate (inside air) to keep the air cool due to all the plastics in cars. To draw hot humid air in from the outside will ensure that it will take at least twice as long to cool the interior.
    I agree that in most situations recirculate makes the a/c work better. An exception might be when you first start up the car and the interior is super-heated from sitting in the sun. I think in that situation fresh air is better than inside air. Recirculate probably saves gas, too.
    But what's the relationship between plastics in the car interior and a/c performance?
  • beedublubeedublu Posts: 236
    I find that anytime the outside temp is much greater than 80F it helps to use recir mode. That's especially true in direct sun. My 04 hasn't had the headlight related problem you've described.
    Actually, my one complaint with the a/c in this car is the design of the panel vents. They don't allow much vertical adjustment, so you either have to endure cold air blowing directly at your shoulder or just direct it far to either side. And that weird pair of registers on the upper part of the panel doesn't do much good...most of the air comes from the lower center vents and the two outboard ones.
  • madmaxxmadmaxx Posts: 44
    "..weird pair of registers on the upper part of the panel doesn't do much good.."
    Those are ment to supply warm or cool air to the rear seat passengers.
    Thanks - that's interesting info.
    I think the upper center vents are supposed to "turbo blast" air to the back seat, and the only time they really work is when you close the lower center vent with the rotary thumbwheel control. Rear passengers have said that they can definitely feel air from those upper center vents if I close the lower center vent.
  • Recent GM cars all seem to have marginal AC - which the GM AC engineers surely are aware of. My guess is that they are using compressors that take less hp to operate so as to increase fuel mileage. I'd prefer better cooling over minor MPG increases.
    Yes, it seems that the newer-design cars are the ones that are getting the lower capacity systems. I think it's not just GM but many cars. I have an '03 S10 that has a/c that gets very cold. Of course, in a pickup, there is not as much inside space to cool, either.
    What I said above was wrong. The thumbwheel opens and closes the rear "turbo blast" a/c vent. To get that vent to work, you have to open its thumbwheel and also close the louvers on the two lower center vents.
    :confuse:
    I don't see how, given that there's absolutely zero air coming out of them...no matter how you position the thumbwheel control that supposedly controls the airflow!
  • meandmymaxxmeandmymaxx Posts: 134
    I think it also has to do with the new environmentally safer coolant they use,R134A is not nearly as efficient at removing the heat as the old R12 use to be. I had the windows tinted on my 05 Maxx.(first time on any of my cars) To me makes a big differance in how hot the car gets and how quickly it cools down.
  • mdennishmdennish Posts: 16
    i live in phx,az and the a/c in my maxx was cooling the car in 110 degree temps, if the car has been outside in the direct sun, ikeep the windows opened 1 inch and run the ac for approx. 5 mins before using the recirculating mode and closing the windows, if the car has been in the shade i start the a/c in the recirculating mode with the wqindows slightly opened for approx. 2 mins and everything is fine. had 4 people in the car for a 2 hr dr. and everyone was satisfied with the a/c with outside temps of 110 degrees. AND I ALWAYS USE MY SUNSHADE on the front window and drape a towel over the steering wheel when parked.
  • csandstecsandste Posts: 1,866
    I'm coming to the end of my warranty so any ideas would be helpful.
    1. Had no heat for a couple of weeks in late April. Was going to take it in at a regular service but it corrected itself.
    2. Since then, on about three occasions, I've had the heat on full blast when the heater controller is off. Not pleasant in late June. This has lasted only a minute or two. I suspect the A/C continued to operate but of course it was totally overcome by the heater. All occurances on start-up with a warm engine.
    Intermittant problems are always pleasant.
«1345
Chevrolet Malibu Maxx Interior and Passenger Comfort Concerns — Car Forums at Edmunds.com
