2001 GMC Sonoma 4.3 liter 4wd auto transmission shifting
wolff_97wolff_97 Posts: 1
edited December 2013 in GMC
My 2001 gmc Sonoma sifts into 1 and 2 fine but won't go into third it will go into reverse if you try to put it in 3rd manually it acts like it is in neutral any ideas?
  • It is most likely your clutches for 3rd and 4th gear. The transmission will need to be removed, and clutches re-done. You will most likely find them burnt up. This problem rarely has to do with the valve body or shift solenoids.
2001 GMC Sonoma 4.3 liter 4wd auto transmission shifting — Car Forums at Edmunds.com
