2004 Ford Expedition Door Ajar, Lighting, and Radio problems
gthompson622gthompson622 Posts: 1
edited December 2013 in Ford
Tonight my 2004 Ford Expedition experienced a couple problems. First when I opened my car door, the convenience/dome lights did not turn on. The lights did turn on when I turned off the car though. When I started the car the door ajar light also came on. I checked each door as well as the tailgate and the tailgate window and the door ajar light stayed on. I had my headlights set on automatic and they did not turn on even though it was dark out and they usually do turn on. I switched the headlights to manual and they did turn on. When I turned the car off the convenience/dome lights did turn on like I said before. The last thing I noticed was that when the key was out of the ignition and the car was off, the radio did not turn off when I opened the car door. I think it sounds like a door sensor. I don't know if it could be the GEM module or a relay or a corroded splice on 2 violet/purple wires that splice into one violet/purple wire that's under the driver side rear door sill.
  • Spray the latches down with WD-40 to clean the contacts off. Do all the doors, including the hatch and lift glass. Likely going to be the driver's door, but good medicine for all of them.
2004 Ford Expedition Door Ajar, Lighting, and Radio problems — Car Forums at
