Nissan Rogue electronic buzzing sound when accelerated
lori37lori37 Posts: 4
edited January 2014 in Nissan
Has anyone experienced this? I have just under 36,000 miles on the vehicle. I've experienced a buzzing sound when I step on the gas; that is, stop at a light, then give the Rogue gas. I took the Rogue into the dealer and a belt was replaced; however, I am still hearing this buzzing sound, although it is not as loud. It's a low buzz, so to speak... (The belt, btw, was still under Nissan's 3yr/36,000 warranty.)
What's with this? Anyone know?
Thanks for any comments.
    turn the car off, then start the car....there is no noise. if u step on the accelerator the buzzing happens and doesnt go away till u restart the car. if that is what is happening....it is a faultly oil filter that is buzzing internally. if that is ur exact issue get a oil change and should be gone. its rare but some aftermarket and yes factory filters too can cause buzzing noises. hope it helps
  • lori37lori37 Posts: 4
    Thanks a lot for your comment. When I brought the car in for the buzzing sound, it also had an oil change/filter done...I still hear the noise, but it's an occasional low buzz...Seems to happen when I stop then step gently on the gas (first gear)...Hope it's not a transmission issue (?)
  • I have a 2014 rogue select about 350 miles. I am leasing the car. I am beginning to think this was a bad move. There is an annoying rumbling/buxxibg sound in the dash. I am taking it to the dealer tomorrow for servicing and am hoping they will be able to fix it. The not see occurs at low speeds. Crossing my fingers this can be fixed. My Hyundai Tuscan was to totalked in an accudent. Any comments or suggestions would be appreciated.
Nissan Rogue electronic buzzing sound when accelerated — Car Forums at Edmunds.com
