BRAKE PROBLEMS
bobbyr549bobbyr549 Posts: 2
edited January 2014 in Ford
Have replaced power booster, , master cylinder and pads pedal still is soft one time goes almost to the floor the next and still leaks down at traffic light.
HELP
  • bpeeblesbpeebles Posts: 4,085
    edited January 2014
    If it is not physically losing fluid... the problem MUST be the master-cylinder. If you installed a rebuilt one...it is VERY possible it was bad out of the box. (There is always a warantee on replacement parts so it is covered.)
    HINT: Many 'rebuilt' parts are very inexpensive (compared to new ones) This is because the rebuilding process is not very good. Instead, they apply a VERY good warantee.because they know the rebuilding process is crap. This is ESPECIALLY true for rebuilt alternators.
    I learned this lesson the hard way by purchasing rebuilt alternator that had LIFETIME warantee..... it had to be replaced at least 5 times before I found a good one. I may have saved some money on the part... but I spent WAYYY too many hours removing/ replacing and taking back to Autozone.
  • Thanks you are right but the first one was Motorcraft and the second was rebuilt, both could be bad?
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,354
    Then it must be how the system was bled. There might still be air in there, or proper procedure on bleeding ABS brakes was not followed ??
    MODERATOR --Need help with anything? Click on my name!
    I still contend that if it is not losing fluid and the pedal truly "leaks down" at a stoplight.... no amount of bleeding will fix a sinking pedal. The problem an internal leak in the master-cylinder.
    It is unlikely that both were bad... so I ask again - Are your certain is is not losing fluid? (which is the ONLY other way the pedal would slowly sink to the floor )
BRAKE PROBLEMS — Car Forums at Edmunds.com
