Chevy Silverado 1500 Overheating Issue
shadetree63shadetree63 Posts: 1
edited June 2014 in Chevrolet
I have a 2006 Pickup, 5.3L with an overheating issue. Initially, the overheating was intermittent, so i figured it was a thermostat (sticking at times). I replaced the thermostat and the problem still persisted, and actually the engine seemed to be overheating more frequently. I then changed the water pump (the old pump was not leaking coolant) and the engine is still overheating. The engine overheats very quickly (within a few minutes) and the coolant boils in the over-flow reservior.
IMO is seems like the coolant isn't even circulating through the engine. I am at a loss as to what the problem could be? Any help would be greatly appreciated.
BTW, the coolant in the reservoir is very clean, so I assume the radiator is as well. This vehicle has never had any radiator damage or had the unit flushed.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 53,751
    From your symptoms, I would have to strongly suspect a head gasket or cracked cylinder head issue, because of how quickly the engine overheats. This suggests to me that the coolant is being boiled by ADDED heat, not just normal engine operation.
    You can test for a bad head gasket by using a coolant pressure pump. You pump it up to a few pounds more than your radiator cap pressure reading, and while holding pressure in the system, extract the spark plugs one by one and look for coolant on them.
    You can also look for water/oil goop on the end of the oil dipstick, but that's often not an accurate test.
    Another good test that requires some special equipment is a cylinder leakdown test, where air pressure is injected into the cylinder.
    Overheating can sometimes be very tricky to diagnose. It's actually part of a rather complex system of interdependent parts, so it might take a while to narrow it down.
    but you either have a bad head gasket or a massive blockage in the water galleys somewhere in there.
    MODERATOR --Need help with anything? Click on my name!
  • lugnuts3lugnuts3 Posts: 10
    How many miles are on it? And i would check your freeze plugs on there,they have a tendency to busy after awhile,and if isnt that,then its more then likely a head gasket,if you notice your loosing oil,or your oil is very fluid like and has a coolant like smell then theres your culprit,hope i helped!
    Bust.^^ not busy.sorry lol
  • steverstever Viva Las CrucesPosts: 51,904
    edited July 2014
    Ah, chat typos. We're all pretty fluent in those nowadays. :) You do have 4 hours to edit your posts here.
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
    Im really new to this site lol thanks for the tip though
  • mcoop360mcoop360 waldo alabamaPosts: 2
    i have a 1995 chevy 1500 w/t with a 4.3 vortec moter has recently started overheating i have replaced the water pump and the and replaced the thermastat 3 times so now i just took it out and my mechanical temp guage want go over 130 any ideas would be very helpful
Chevy Silverado 1500 Overheating Issue — Car Forums at Edmunds.com
