2006 Honda Odyssey sounds
angeldoveangeldove Posts: 1
edited July 2014 in Honda
I would like your thoughts regarding some "sounds" that I am hearing coming from our 2006 Honda Odyssey. We had to have a new transmission put in recently so I don't know if this first sound I will describe has anything to do with that or not. Sometimes (but, not always) when you back the car up, there is a noticeable "pop" sound. Any thoughts?
Also another thing I notice is that when the car has been parked for a little while like over nite and you crank the car, it sounds like there is a lot of under hood noise for a few minutes and then it quiets down.
We also are having paint issues with this model and the left passenger left side door at times won't slide open automatically.
Another issue is putting in gas. The gas nozzles keep shutting off, so you have to have a feather lite touch when you try to put in the gas.
Any input would be greatly appreciated.
  • On my 2007 honda Odyssey, I have noticed the sound coming from the engine during cold engine starts. After the engine is at its operating temperature, it goes back to normal. About the "pop" sound, it may be when shifting the gear out of park. When the car has been parked overnight possibly on an inclined road or driveway, I had noticed that happening.
  • We have enjoyed our 2006 Oddy, but it has problems. We hear a strange sound like rubbing plastic whenever you give it a little gas. One mechanic thought it was something rubbing against the air intake since he found a whole in it and the air is bypassing the air filter. I have also noticed a burning rubber smell. The rubber belts have been replaced recently, but I have been thinking one of the tensioners or idlers has gone bad. The front axle boots look good. Any suggestions? Thanks for whatever help you may have to offer. Happy Hondaring!
2006 Honda Odyssey sounds — Car Forums at Edmunds.com
