Isuzu Trooper Starter issues
Hello there. 2001 trooper with gremlins. It started a couple months ago when all of a sudden the power window stopped working the ABS lights came on and the TOD lights went out completely. The trooper ran fine up until about a week ago when it had a hard start at the gas station and I drove in a couple blocks home and then it wouldn't start. When turning the key over I just got a single pronounced click from the starter. Went through the usual tricks of the trade i.e. tapping the starter jumping the solenoid with nothing starting the vehicle. I switched out the battery for a known good one and still nothing. I pulled the starter and had a bench tested at Napa and it seemed to work fine of course it wasn't under a load but it's all I got for now. Replaced everything hooked back up all the wires now I don't even get a click. Tried jumping the solenoid again and nothing. I've tested the wire at the solenoid I have 12 V I just can't figure this out and really need to get this thing going. Any help would be greatly appreciated. I thank you in advance for your help.
Answers
Did you check the engine to frame ground strap and the battery cable connections on the starter and frame ends?
did you check your neutral safety switch (or clutch safety switch if a manual transmission?)
Yes the neutral safety switch would interrupt to the solenoid but not if you jumped directly from the battery.
Sometimes starter armatures have "dead spots", where they may or may not activate, depending on where they landed on the last spin.
