Honda CR-V Maintenance and Repair
What problems have you experienced with your CRV? Please share any solutions!
KarenS
Owner's Clubs
KarenS
Owner's Clubs
Thanks for any suggestions/comments
coolnik
'99 CRV
99 EX
45K
Some owners have corrected PTTR by having their tires rotated. Others have replaced the upper and lower control arms. Many have found that their dealer was out to lunch when Honda taught proper alignment specs.
Here's a pic. It may be too big for this format. If so, try this link.
Oh, and I'll also recommend that you find out how they "fixed" it the first time.
the dealer this afternoon appointment. i hope
they could fix it before my long trip tomorrow.
I encourage you to do this as the cruise control does not in any way regulate rpms. That is the job of the on-board computer. Check this link for more info about cruise control in general. It references early model CR-V's, but maybe you'll recognize something helpful.
http://www.ptcruiserusa.com/hondasuv/crvix/underhood/Cruise_Control.htm
in the dealer's lot/garage/basement?
The one on top of the seat back next to the head rest that you pull up to flip the seat back forward?
It screws on, so use a pair of needle nosed pliers to grab the remaining piece to unscrew it. Get the part from your local Honda dealer. They knob only runs about $3.50. Ordering it online doesn't make sense because you'd have to pay for shipping.
all honda dealers are mandated to perform those
if and when required?
so go to a dealer which could solve your problem
and tell us who the dealer is so we would avoid
them
THanks
I recently bought a 2001 CRV LX but without
keyless entry. It costs an extra $350(?)from
the dealership. I've seen handa accessories.com
selling it for $66 (apparently, the receiver in
the car is factory-installed in all CRVs). All
you need is to buy the transmitter and program it.
Is this true? I wonder how one CRV will be uniquely unlocked by a generic transmitter. Thanks
for any help!! - Robert
My honda dealer says that this is a characteristic of the vehicle.
An independent mechanic said that it is a wheel bearing problem.
Has anyone else had any problems with a whining noise or wheel bearings?
Please post a reponse or email me privately at
[email protected]
you can get two types of hydraulic jacks a canister type -- small round jack that is telescopic but slow, or a lever type (one i got) that is bulky and heavy, but provides quick lift in two or more pumpings. i got mine long time ago when caldor was going out of business, but you can check out auto zone, pep boys, sears, home depot, strauss auto, napa, and bunch of other stores. you don't need a truck type jack since your car is not over 5000 lbs.
Has anyone found a national chain that can (cost effectively) replace the CR-V muffler? Did they use a muffler designed for another Honda car?
but seriously i have modified the stereo and now i don't even hear the wind.
check out my mods at http://www.blueiedgod.com/subs.html
or the whole page
Chuck
I have a 2001 cr-v se and am looking for an add-on remote starter that will work happily with the existing remote entry system. Does anyone have any information on this? I'm going to install it myself and want to use the same key fob that came with the V. Is there a place where I can find the wiring diagram for the factory remote entry module? Any info is appreciated. Thanks.
I hear you. Last night I noticed the exact same thing happening to my 99 EX automatic, for the first time. You described EXACTLY the same conditions under which it will "click". Any luck finding out the cause?......
Bob
I stop or take off from a dead stop I get this creaking noise. Has anyone else experienced?
this type of problem.
Bottom line...the mechanic said I could have avoided this problem if I had the valves adjusted every 30K or so. Costly lesson. The adjustment only cost about $90. The dealership in IL never suspected the valves. Would have been nice to know this before I started on a 1500 mile trip.
My CR-V is at 108K now and going strong. This is the only problem I have ever had.
