Millenia squeaks while driving
1st_millenia1st_millenia Posts: 3
edited March 2014 in Mazda
Hey everyone.
I recently purchased a 1998 Mazda Millenia (base model) with 68,000. Yesterday, I heard squeaking noises coming from the rear of the car (to the best of knowledge). The squeaking is not terribly loud or noticeable while driving on smooth road; it's more noticeable while driving on bumpy road. Also, this squeaking noise is audible when I'm getting in and out of the car.
I think the problem lies in the suspension. Has anyone had this problem or can give me a detailed diagnosis? I really appreciate anyone reading my post! Thanks.
  • My car does the same thing...I have a 97 S model and I've noticed when going over either speed bumps or rough roads...you can hear it big time...I'll be checking the board for an answer...
  • acabral1acabral1 Posts: 122
    Your coil springs may be rubbing together.
  • swschradswschrad Posts: 2,171
    you could have bushings dry or worn on anything such as shock bolt areas, spring attachments, etc. try a little WD40 as a test. if that cleared it up, spray one of the thicker silicones in that area for a stopgap fix. if this area is a rubber bushing, and you see mushrooming or cracks, or pieces missing, it really needs to be replaced.
    or maybe trade for another car that squeaks in your key, so you can sing along ;)
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 53,908
    Or visit the "rodent" topic on this board (just kidding, couldn't resist).
    MODERATOR --Need help with anything? Click on my name!
  • My '98 was doing the exact same thing at about 32K miles. Dealer replaced the rear trailing arms under warranty. Problem solved.
    Hope that helps.
Millenia squeaks while driving — Car Forums at Edmunds.com
