Frozen rotor
Anyone have advice on how to remove a frozen rotor off a 93 Accord? I pryed until I feared destroying something and pulled till my fingers were numb. Thanks
Accord only:
- remove spindle nut
- raise and support vehicle
- remove wheel & tire, brake caliper (support it)
- disconnect outer tie rod from steering knuckle
- separate ball joint from lower arm using suitable puller
- * take care not to damage rubber boot on tie rod or ball joint
- separate outboard CV joint from steering knuckle
- remove 4 bolts holding hub/rotor to steering knuckle, then remove hub/rotor from knuckle
- remove 4 hub to rotor bolts and separate rotor from hub
Assembly:
- torque hub/rotor bolts to 40 ft. lbs.
- use new hub/knuckle self locking bolts (or blue Loctite) and torque to 33 ft. lbs.
Worst comes to worst, you can take the distributor out and then you've got the little bugger in your power......
I also have a 97 and a 2000. Are they the same way?
