2000 Olds Alero-Turn Signals quit (sometimes--Help!
sewheel
Member Posts: 3
My 2000 Oldsmobile Alero is having blinker problems. Somedays the just don't work at all. The light doesn't flash, it doesn't make that "blinker" sound or nothing. But some days it works fine. I take it to the dealer and of course they say it is working fine and their is nothing they can do about it. I don't know what else to do. I can't have my blinker just quit while driving around the city. This is annoying. Does anybody out there have any ideas on what might be wrong?????
Any help would be greatly appreciated.
Stacie
Stacie
If your under warranty, no problem. If not, it's about a $150 repair.
I doubt if bad bulbs, grounds or wiring is a problem on such a new car, but of course it doesn't hurt to check.
I've seen three Grand Am's with exactly the problem your're describing (one belongs to my daughter) and it's been the combo switch on all of them. In most cases, the signals, high beams, and brake lights are either all intermittent at the same time or in some combination. The Alero and Grand Am are the same in this design.
I didn't find any TSBs on the lighting system either. Just curious where you got that from. Maybe I can locate the TSB then.
Since that time I've advised two other owners with similar symptoms and it's turned out to be the problem.
My 99 Grand Am hasn't had a problem in this area (yet!).
/direct/view/.ef0627d
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
File Not Found
The file you have requested was not found. Edmunds.com does not recommend bookmarking vehicle detail or editorial pages. If you wish to bookmark Edmunds.com, we suggest you bookmark our homepage at http://www.edmunds.com.
All indications (no pun intended) are the turn signal switch itself is bad, if they go out again see if the hazards work, if not it's definitely the switch. Take it to the dealer tell them you want it changed under customer satisfaction, magically they will re-create your problem and charge it to the warranty.
Sorry 'bout that. My fingers went too fast for my brain.
kirstie_h
Roving Host
Edmunds.com
