Integra suspension worn out? Help!
tph98tph98 Posts: 1
edited March 2014 in Acura
I have an '87 Integra with 152K milies, and relatively new shocks (or whatever they call them), but the front end still bottoms out at any kind of dip in the road at even modest speed. What probably needs replacing? Any repair shop recommendation in Los Angeles/LAX area?
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,387
    Maybe springs or maybe the shock tower dampers. Can't help you in LA but if you're ever in the SF area........:)
    MODERATOR --Need help with anything? Click on my name!
  • You probably need new coil springs if you can feel the car bottoming out. Have a mechanic you trust check out the front and rear suspension to make sure everything is tight. Good luck.
Integra suspension worn out? Help! — Car Forums at Edmunds.com
