How often should I replace fuel filter?
I can not find any reference on fuel filter replacement on the owner manual for my Infiniti G20. Please let me know how often should I change fuel filter and does it really matter? Thank you
Chris
See Also: How to Change Your Car's Filters
Chris
There are a number of things that should be done if you plan on keeping a car past 100,000 miles, but most car makers know that most people won't, so they don't mention them.
Leo
I do mine every 30,000
Leo
Maybe the Toyota has a built in fuel pump/filter ? but I doubt it,
Brucer2 was right about the regulator/returns..
most pumps just pump and the regulator just regulates injector pressure so the rest just recirculates.... I would just replace the filter periodically anyhow, no sense in burning out the fuel pump pre-maturely....they normally have a limited life anyway but no reason to make it shorter!!
good luck, general advice,,, if its a filter, change it regularly, you'll come out ahead in the long run..
Rando
Also several top techs who run Toy web pages say never change them -
i can not explain it.
On my Chevy truck fuel filter one time after replacing, I blew backwards through it into a jar to see what type dirt was in it, I saw plenty of sand and small metal flecks, made me appreciate that it was doing something for the team.
Sounds like Toyota has saved you some $$$$ and some work somehow,,,If you find out how it does that let us know and maybe we can do it to our trucks?
see ya
Rando
Hi to all, the reason I found out that Lexus does not recommend a replacement of the fuel filter, is that it is to hard to get off, you end up breaking the fuel line because the threads were damaged when the factory put them on and rust has built up and they wont come off, once you twist a line the complete line has to be replaced.This means if you fill up with a bad tank of gas it could cost you more than a filter replacement. Also as miles build up the filter gets dirty and this causes your pump current to go up because it has to push harder, good practice on most cars would be to change the filter at least every 15K to 30K not Lexus, they will tell you that the filter last the life of the car, make sense to you? I have cut them open and they are built the same as any filter with a paper element. The Trans filter they will say it is a screen and does not need to be changed, I have had this filter out and even with 200K miles on LS400s it has not looked clogged, so if the car is not driven hard they may have a point on this filter, by the way the way around the fuel filter on my car was to cut the line with a tubing cutter add high pressure fuel hose and install a K&N filter, the shops cannot do this it would be a liability nightmare."
So essentially Toyota/Lexus is correct in that the fuel filter really doesn't need to be changed. interesting. Like I said before, I've only changed the fuel filter once on my '94 Toyota Paseo which currnetly has 176,200 miles on it.
Leo
There are a number of items that owner's manuals are mute on (transmission fluid, brake fluid, PS fluid should all be changed), but don't have much impact on reliabilty during the first few years and first 100k miles. This isn't to say that every fuel system will give problems in its 2nd 100k miles if the filter isn't changed, but it will greatly less the likelyhood if it is.
Morale to the story-buy you gas from big high volume stations-not many other around. If you do get a bad load of gas-well you will know it asap. I would not change fuel filters if there are no problems. Some of them are clear and you can see if they have crud in them.
Newer cars do not have any canister type fuel filters. The filter is a flimsy plastic sceen pocket attached to the bottom of the fuel pump pick up tube inside the gas tank.
My old 95 Dodge Stratus did have a replacable canister type fuel filter. The problem was its location. In order to replace the filter, I had to drop the gas tank. Way to go Chrysler.
I agree with you, the owner manual is pretty mute on a lot of maintenance issues. I would never have guess that I'd have to argue/fight to have what I would think would be routine maintence. Go figure? But if my car makes it to 200,000 miles I consider that I got my money out of the car.
Leo
Leo
I hear(not verified yet)that Honda Accord 98-present is the same way.
However, what I consider lifetime and what Chrysler considers lifetime are, I'm sure, two different things. I'm guessing that, roughly translated, "lifetime" means it's in the fuel tank, and is going to cost a few hundred $ to get to?
Performing such proactive maintanence will not in any way be a detrimental to the mechanics of the vehicle, I believe it can only contribute to it's running efficently and optimally thus averting any higher repair cost incured due to neglecting such maintanence.
