Honda Accord 4 cyl/150HP automatics get very dissappointing gas mileage
I have a 2001 Honda Accord LX 4cyl/150hp automatic that I bought new a year ago and I am very dissapointed in the gas mileage that I have been able to obtain. The car is meticiously maintained, I'm a mechanic. The car was broken in properly, 5W-20 weight oil is used and correct tire pressure maintained. In over 15,000 miles of driving using a very conservative driving style I get 21-22.5 MPG in the light flat city driving and 27-28.6 MPG on pure flat interstate 10 driving. The car is rated at 23 city/30 highway. I have never owned a car that I didn't exceed EPA estimates by at least 2 or 3 miles per gallon. I have had Honda check out the car and they changed the computer, but the mileage stayed the same. I have also talked to several people that have a Accord like mind and they are in the same boat. Accord's gas mileage is just not very good when compared to a like cars, Camry, Altima etc.
Just trying to help. Resume complaining about your mileage at your leisure.
Great way to decrease imports by 15%.
My heavier? 94 Camry 4 cyl does a lot better and its LOW tech
I was a little disappointed in my mileage when I first got the car but decided that it was worth the price for the additional power over what I originally expected from the car. I think you should be upset if you are not averaging at least 24 MPG and have the dealer check it out. Something sounds wrong.
Do you park in a garage at night ? notice any gas smells ?
Also, has the dealer confirmed that your speedo /odometer is set up correctly ? (I don't know if these are gear-driven on the Accord, or if it's entirely electronic.) For example, on my Jeep, there's a small plastic gear that triggers a sensor that tells the speedometer how fast I'm going, as well as how many miles I've traveled. If I change any variables such as axle ratio or tire size, I affect the final drive ratio, and will cause the speedo/odo to be inaccurate.
Correcting this inaccuracy is done by changing out the plastic gear to one with the correct tooth #.
-Karl
Got a 97 i4 accord-did a 380 mile road trip, 80 miles at 63mph and 300 miles at 80 mph with ac on most of trip-used 12.2 gallons of gas-same pump for both fills and filled it to the top each time-that works out to 31.1 mpg. Usually get from 29 to 32 MPG and drive at 80 most of the time.
