Shop did Radiator Pressure Check-Now water in Oil
pmscrazypmscrazy Posts: 4
edited March 2014 in Pontiac
My husband took our 1992 Pontiac Grand Prix,3.1L to a Repair Shop to have them do a pressure check on the radiator. Jeff (my husband) has replaced and done everything to the cooling system,including just having the radiator rodded out. He still didn't think there was good circulation.The Mechanic told Jeff when the other employee came back from lunch they were going to do test at 16lbs.Jeff picked up our car and told him "no charge". On the way home the car died. Jeff thinking he was out of gas,(gauge doesn't work)put gas in and heavy tapping from engine is now being heard. Jeff checked the oil and it was brown colored. He changed the oil (kept it) and no change.There was absolutely nothing wrong besides circulation! This occured today,1-6-03.He's going to shop tomarrow.Need Advice Please!! "Thank You"
  • swschradswschrad Posts: 2,171
    good luck... they may have overpressurized the system and taken it out, it may have been on the brink of failure anyway.
  • "Thank You Scott Schrader" for your response! We were wondering if it was possible that the mechanic was at fault or not. Nothing was said to my husband as he picked up our car about any other problems and told him they didn't find anything wrong! We needed alittle incouragement! Jeff is going to confront shop this morning, very upset and can't sleep at moment! :)
  • alcanalcan Posts: 2,550
    Read this before blaming the repair shop. Click on "View signatures" to read some owners' comments:
    http://www.petitiononline.com/mod_perl/signed.cgi?GMcnsmrs&1301
  • isellhondasisellhondas Issaquah WashingtonPosts: 19,067
    I don't think pumping a radiator up to 16 PSI caused the problem. I think the problem existed before the shop touched the car.
    It's easy to blame a shop for something they didn't cause.
  • orwoodyorwoody Posts: 269
    16 psi shouldn't be enough to do any real damage but would uncover a leak. I had a 3.1L on a used 1996 GP that had a separated head gasket. It was most prevalent once the engine ran for a while and the heat caused slight different expansion of the head from the block allowing some coolant to get sucked into the cylinders. Lucky my problem was found before catastrophic fail.
  • 0patience0patience Posts: 1,542
    pmscrazy,
    Hold on now.
    There is no way that pressurizing the cooling system "wrong" is going to do anything more than blow hoses. If the headgasket failed after pressurizing the cooling system, then you had a problem to start with.
    Pressurizing the cooling system is a time tested diagnosis and only harms the system if you already have a problem. More than likely, it started to dislodge a head gasket that was already failing and once the vehicle got up to operating temp, it finally failed.
    Don't go blaming the mechanic until you are sure what you and anyone you are getting info from, know exactly what you are talkig about.
    As Alcan pointed out, these engines have known cooling system problems and more than likely, is the cause of your problem, not pressure testing the cooling system.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,721
    I'd have to agree, this is not the mechanic's fault, especially given the type of car and the problem.
    MODERATOR --Need help with anything? Click on my name!
  • Had a similar problem. This car has the 3800-II engine and 62K miles. Several gaskets (intake and plenum) failed and had $1800 in repairs. I believe these failures are related to post #4 (SEE link). You probably aren't using the red/orange Dex-cool coolant, so it may not apply, but more than likely, looking at a head gasket/intake gasket problem. Check for the coolant starting to discolor and accumulate sludge in the reserve tank, these are signs of trouble (not to mention sludge build up in the radiator) My car had a catostrophic failure one day where there was just too much coolant in the cylinders and car would barely run, blew out several sensors too. I don't think it's too common on the 3.8's, more so with the 3.4 and 3.1's. Gasket failures such as these, typically occuring at 40-60K miles are premature, yet GM at this time claims no defects or liability.
  • I'd just like to "Thank" everyone for your input. We have already begun to take apart the engine and replace the head gasket, then have mechanic check the internal parts. We Aren't for sure that it was the shops fault, nor putting all the blame on them, this is a subject we're not familiar with,and just wanted to get opinion of others. Others have told us you can over pressurize system, so had to do some research! It's a pain in the rear, but one that we are dealing with! Sincerely, Jeff & Pam
    for instance, using the hand pump that screws onto the radiator cap's neck, you can't get that much past 18 or 20 pounds. anything you blow up with that tool was a dead part anyway, just hadn't fallen over yet to call your attention to it.
    now, if somebody came back from welding class saying "looky what a neat tool I made here," and it happened to couple shop air to the cooling system, I would suspect 120 psi and up is likely to wreck the cooling system as surely as a sledgehammer.
    technicians who know their subject instinctively avoid such gonzo approaches....
    sorry you have a premature repair, 0patience said it way better than I was trying to say, it was already dead. I suspect you had reason to want the test done, and that reason was correct, the issue bugging you ended up being a big one.
  • jgmilbergjgmilberg Posts: 872
    The mechanic can't really fix it w/o a big repair bill. At the very least you are looking at a crankshaft turning/weld and a set of rod and crank bearings. If there was a true rod knock, there is a really good possibility of an out of spec rod end and to fix that the piston/rod assembly needs to be removed and re-sized. By that time a complete rebuild won't cost that much more... It's time to decide wether the car is worth that type of repair and go from there. It might be better to fix the car than it is to have a car payment. If you can't afford the repair, but like the car enough, you could re finance the car for the cost of the repair.
Shop did Radiator Pressure Check-Now water in Oil — Car Forums at Edmunds.com
