2013 VW Jetta 2.5SE damaged oil pan or worse?
awa67894
Member Posts: 1
2 nights ago I was driving around the neighborhood. I was coming down a small hill to a stop sign where I could only make a right or a left. I proceeded to turn right and a dog ran in front of the car. I swerved to the left, managing to not hit the dog but run flat into the sidewalk. In the moment it felt like my bumper had just scraped the edge and it sounded like I had just scatched the bottom of the bumper. I proceeded down the street for about 2-3 minutes before my car started slowing down. The engine was still on but when I pushed down on the pedal to accelerate the engine just revved. When I looked down to see if maybe I had knocked the car into neutral, I couldn't move the shifter and it appeared to be stuck in reverse? When I tried pulling my car to the side of the road I found that now my steering wheel was also locked up and could barely tug it enough to get it moved over. Finally, I made it to the side of the road and now my brakes were locked as well. I managed to stop it with the e-brake but still the shifter wouldn't budge to put it in park. I turned the car off to avoid damaging the engine. I didn't address this problem immediately so I came back the following day to check it out, and couldn't get the car to turn over. I had power, the battery was fine, the engine wouldn't even make a noise like it was trying. Eventually I looked underneath the car and saw the oil leaking from what I believe is the oil pan? This is my first car and know absolutely nothing about how an engine works. Can anyone diagnose this problem? I'm taking it to the dealership tomorrow because it is the weekend but would still like to know if anyone has ever heard of anything like this. I've posted a few pictures of what got hit to give you a better idea. Could this be a computer response so that the engine doesn't seize? Again, the brakes, the gear shifter,and the steering wheel are all locked and won't budge. I used the emergency release lever to realease the gear shifter and was able to pull it into neutral and start the engine but I had to hold the shifter firmly the whole time and if I let go it would pop back into reverse(but it still rolls forward like it's in neutral?). Is this something a warranty or insurance would cover? Hopefully this is just the oil pan because I do not have a fraction of the money to get my transmission or engine entirely replaced.. It's a 2013 VW Jetta 2.5SE with 45k miles on it.
