«134
  • jraskejraske Posts: 133
    Iwould like to here from other people what they think of leather seats compared to cloth os far as comfort and durability are concerend.
  • pchengpcheng Posts: 165
    Leather definitely. I've had both and I prefer leather. It's more comfortable and easier to clean.
    My wife likes cloth because it's not as cold in the winter and not as hot in the summer, but I've found that the comfort, once the temp balances out, is well worth it.
  • lvstanglvstang Posts: 150
    It matters where you live but pcheng's wife is right as far as Vegas is concerned. Leather is unbearable in the summer and too cold in the winter in my Cobra. Had cloth on F-150,much easier to ingress and egress with tank top (or less) and shorts on.
  • RoclesRocles Posts: 985
    Leather is fine for a car,actually the best choice. For trucks?? No. Something about leather in a truck that makes me cringe......
  • vince4vince4 Posts: 1,272
    I've seen many cars with awful looking leather seats after a few years. They crack and sometimes split open. I suppose good care would reduce that but that means you have to actually do it, I suspect most people don't. Another consideration is scratching from dog toe nails, if that applies.
    After living with leather furniture at home, I ordered the cloth seat in my new Silverado. The hot/cold comfort thing is real. Also leather is slippery and doesn't hold you in place well in a car.
  • Hot in the summer, cold in the winter. But the good part is you can slide around on the seat to get comfortable. Leather doesn't grab at your clothing the way cloth does.
    Worst part about leather, is how little of it they are actually using on seats anymore. No tanning in USA due toxic waste.
    The imitation leather they use for the rear seats of the Silverado/Sierra looks good. I can't tell the difference by looking at it. Would anyone buy it if they offered as a no cost alternative to cloth, or instead of the vinyl used on base models?
  • tommctommc Posts: 68
    I just had some seats repaired for a truck I'm reworking. Good cloth material these days is going for 33 bucks a yard. I really suspect that the factories are saving money with the small amount of leather being used with the balance being vinyl material. The leather is paper thin, lightweight, and would be easy to stitch. Has to be a reason there's so much of it now. I had leather on my last new car, won't again. tom
    I used to have cloth seats in my old truck. I've found that the leather is easier to clean for most stuff. Unless you are completely muddy, which would stain cloth as much as leather, leather is much easier to keep clean.
    All you have to do is wipe it up with a damp cloth. I have a Camry with cloth seats, and with two kids, I can already see spots in the back seats from feet and spilled juice. The leather in my truck (car seats in the truck too) looks as good as new.
  • mgdvhmanmgdvhman Posts: 4,162
    Best all around.
    Easy to clean. Very rarely splits.
    Fastest to heat up and cool down....regardless of what anyone says.
    Looks way better than cloth.
    you Do NOT slip around.
    Very durable.
    Combine heated seats with leather....
    Ohhhh yeahhhhhh.
    - Tim
    Leather is fastest to heat up and cool down? Faster than what, stone? Cloth doesn't need to heat up or cool down, it's already neutral when you get in.
  • Leather was a "must have" for me. I saw a Dodge Ram with camel tan interior, rosewood applique, 24V diesel, 5 spd, hot!
    Leather isn't an option for a Silverado regular cab, although you can have aftermarket leather covers installed by Sew Fine for a reasonable price.
    But one by one, I started paring my wish list down, and diesel power and leather did not make the cut. Because of the money I saved, I'm very happy.
    As it is, I can't stand a stain or smudge, so I have designer bed sheets as temporary, washable slip covers until I find some that fit the Chevy seats with integral seat belts. With leather, I'd be even more anal, so what's the point?
    I'm flashing back to my Vinyl days.
    Cloth does too get cold.
    Not hot so much.
    Here we are...spewing about another personal preference catagory.
    Who started this?
  • ww00650ww00650 Posts: 48
    Leather always smells like new. So you always have a new smelling truck, as long as its clean, and no one farts.
    Leather is for cars. Personal opinion.
  • z71billz71bill Posts: 2,000
    My Silverado LT came with leather standard - Also has the heated seats - I had the chance to try the heater yesterday worked great, took less time than I thought to heat up. The other benefit to the heater - I like to have the a/c on high and my wife gets cold. Now I just tell her to turn on the heater in her seat.
  • I purchased a 99 Toyota Solara and within two weeks I had what looked like two small wear marks on the drivers side bolster. It appears just the friction of my body rubbing against the seat caused the wear.I had the seat replaced under warranty and again within two weeks the new seat started to show the same type of wear. The leather is very thin. I've taken the car to several detail shops and spoken to the local dealer who agrees that it appears there is nothing that I'm doing to cause the wear that's out of ordinary.Toyota has told me its my problem and refuses to repair or replace the seat. Anyone with this type of problem or someone with answers?
    In my observation, Japanese cars use bad leather. I see cars that aren't that old with leather cracked open. I think Acura is the worst. A friend at work has a Maxima and the areas of the seats that the sun hit a lot are hard as a rock.
    Probably the best you can do is put leather treatment on them regularly.
  • I've had leather in 5 cars, 95 BMW M3, 96 Cobra, 97 BMW 528, 98 Lexus GS300 and my 99 Silverado. I like the Lexus the best, the Cobra was second, 3rd for the BMW528, 4th Silverado and the BMW M3 is last. The Lexus is so soft (held you more in the seat than any leather i've encountered) and easy to clean it's incredible. The Cobra's cleaned easy and lasted ok, but was to "slick". The BMW528 had more of a textured finish and was a pain in the .... to clean. The M3 was worn to the point where it had to be restained (for a lack of a better word). The Silverado is not bad, I just don't like the fact that the leather is only "in the middle" of the seat and the rest is "corinthian leather" - as my wife likes to put it. Best cleaner and conditioner I have ever used is the Lexus brand.
  • Leather: The good:
    Smells great.
    Looks great.
    Feels great.
    You can slide around on the seat to get comfortable without it grabbing, pulling, tugging on your clothes.
    Leather: The bad:
    They don't use much of it.
    For me, leather went from a "must have," to a "I have to sit on top of seat covers anyway, I will never see it or miss it."
  • I have a 97 ford truck with leather seats.it has cracks in it. The truck is just 3 yrs old. i have taken care of the seats and put treatment on the seats regularly. The truck is out of its warrenty and the dealer said to bad you should have not got the leather seats as they don`t last near as long as the cloth seats do. I thought leather material for seats would be at least as durable as other material. Its not! don`t spend the high price its not worth it. PS The extended warrenty will not cover it either.
    Leather is a myth. Ask any biker who's honest and they'll tell you that leather bags don't last as long as synthetics or nylon. Now why would car owners think that leather is superior in durability? I threw out my last pair of leather bags ten years ago and have stuck with the Synthetics.
  • That pretty well sums it up, except if you have heated seats(which my LT does) you only have the problem of being hot in the summer. It's like everything.......a personal choice.
  • rrichfrrichf Posts: 212
    Rocles,
    How right you are! My lap top case in nylon lasted through 2 lap tops or 5+ years. My new leather one on wheels is showing it's age at less than 6 months.
    Rich
    How right you are about "Personal Choice". Kinda like the rear seat in the Tundra, yeh? ;)
  • Ouch !..........
  • I really had a hard time finding a new F-150 this past summer without leather. Trucks are all about image and the only ones left on the local dealers' lots this summer had leather seats - I did not want that. As far as my Ford trucks are concerned, I have had excellent luck with the cloth seats. They have cleaned up over and over with good cleaners - even coffee stains. And, they have not worn badly at all. We live in the mountains with lots of mud/snow/etc on the seats. We spend the summer boating - wet bathing suits jumping in and sitting in the truck. I could not imagine wanting or trying to maintain leather. (I am very happy with the cloth seats on my 1999 F-150 after several months of both of the above - they appear to be holding up just as well as the ones I have had in the past.)
  • jcmdiejcmdie Posts: 595
    For some image may come into play. The plain and simple fact is that leather looks newer longer because it is easier to keep clean. Cloth seats can come clean but it takes more time cleaning and more time for the fabric to dry. I like my cars and trucks clean. Driving a clean vehicle just makes you feel better. It could be 15 years old and clean and you can feel good about driveing it. My truck has an extended cab and it's black. Cleaning time is important.
  • My 1988 F-250 has the original captain's seats (cloth - light gray) and you would be hard pressed to find any sign of wear. The truck has 150,000 miles on it -we had used it (before the new F-150) for 10 years of boating. I really don't think jumping into leather seats with wet bathing suits - without special seatcovers - would have rendered the same results. (I know - I don't do that, but I have had plenty of passengers that did.)Believe me, I know about keeping trucks clean too. We drive many miles of dirt road daily - the dirt gets inside no matter what you do, not to speak of the mud/snow. This particular truck is dark gray. My point: if you keep cloth clean (very easy to do when you notice a stain) it is most likely to be at least as durable than leather. If you do have to put new covers on the seats - you're still dollars ahead of the leather that you originally purchased.
  • page3page3 Posts: 55
    I've had both,and if you like a dust mop to sit in then cloth is for you. I drive dirt roads daily and found it hard to keep dust out of the cab. At least leather keeps it out of your seats and cleans up easy. High temps. are not a problem,just don't hop in with shorts on. My company truck "99 Ford HD" has cloth seats,6 months old and the seats are already fraying.
  • afs11afs11 Posts: 87
    I used to hate leather seats, until I was given a car ('97 Monte Carlo Z34) to use for business. I loved the seats in the car. Yes, they were a bit warm in the summertime. I got used to the leather, & now would never have anything but.
    My new truck will have the heated leather bucket seats. It was easy to choose for me!
«134
Leather vs Cloth Seats — Car Forums at Edmunds.com
