Engine light on
The engine light is on and auto zone says it is a evaporative emission system problem. Purge/ vent. What is this and is it an expensive fix?
Best Answer
imidazol97 Member Posts: 27,154
Which Pontiac and which engine do you have?lanie1944 said:The engine light is on and auto zone says it is a evaporative emission system problem. Purge/ vent. What is this and is it an expensive fix?
Do you know the number (P0XXX, like P0442) did the code reader find?
That's a hint. I don't recall the list but one can be a "large leak" which might be the gas cap not sealed. After
the car does two successful attempts at checking vacuum, the light will go off if that fixed it.
However, there are certain engine temperature and gas tank fuel levels within which the
computer does the evaporative check after startup. Lukewarm engine restart and gas tank
between 15% or 85% are sort of the range.
The rubber seal on the gas cap and the tank surface it touches which can have a rough
deposit on it can prevent sealing with age. Apply vaseline jelly and that sometimes helps
rejuvenate the seal.
A common problem is the purge valve on the 3800 which is on the front of the engine
and opens to let the engine apply vacuum to the tank. These can go bad and are easily and
cheaply replaced if that's the problem.
Good luck. As long as the light is not flashing, it's an emission problem and not fatal.
5
Answers
I have a 2008 Torrent.
