The Great Hybrid Battery Debate
SylviaSylvia Posts: 1,636
The great battery debate is on!
What is the replacement cost? Is there a replacement need? How does this impact the total cost of ownership over the lifetime of the vehicle?
«13456733
  • Panasonic Prismatic HV NiMH battery used in 2004 Prius is rated for about 10,000 recharge cycles until capacity(amount of charge that hold) is reduced to about 80%(1.2KW) of the original(1.5KW). I would assume, you can still drive the car with 1.2KW battery but efficiency(mpg) would be less.
    Panasonic Prismatic HV NiMH battery module.
    Typical consumer electronic cylinderical NiMH battery. Note: Recharge cycle is only 500.
    Dennis
  • The latest generation NiMH battery used in 2004 Pruis are prismatic(rectangle) shape. It has higher power and energy density.
    Prismatic Module Spec:
    Nominal Voltage: 7.2V
    Nominal Capacity: 6.5Ah
    Speceific Power: 1300W/kg
    Speceific Energy: 46Wh/kg
    Weight: 1040g
    Cylindrical Module Spec:
    Nominal Capacity: 6.0Ah
    Speceific Power: 800W/kg
    Speceific Energy: 40Wh/kg
    Weight: 1090g
    Dennis
  • First, let me clear up the vague use of "battery". There are many types of batteries. The most polluting types are lead-acid, Nickel Cadmium(Ni-CD)and button(Mercury) batteries. Lead, Cadmium and Mercury are heavy metal that pollutes the environment if they make contact with human directly or indirectly.
    Ni-Mh battery used in Prius is much more environmental friendly. Nickel and Metal Hydride are not heavy metal or toxic. Nickel can be found in 5 cents literally. There is still the need to recycle Ni-Mh batteries because Nickel recovered from recycling pays for itself! This is not true for other batteries.
    Dennis
  • 2004 Prius has 1.5 KWH(kilowatts/hour) battery and Civic Hybrid has about 1 KWH battery. How big is HV battery capacity compare to pure electric vehicle(EV) battery?
    Toyota Rav4 EV had 28 KWH EV NiMH battery to achieve 87 miles range when travelling at 60mph. That's more than eighteen times larger than Prius battery. In order for Rav4 EV to have the same range of hybrids(700miles), Rav4 EV will need to have 225 KWH battery! To be fair, acknowledge that Rav4 is a heavier SUV and Prius is a mid-size sedan.
    Dennis
  • midnightcowboymidnightcowboy Posts: 1,978
    Somehwere , it was stated I think by John that the Prius battery was 100 times the size of normaly batteries. Bascially kilowatt is 1000 ampere-volt hours assuming the impedence is purely resistive and does not contain inductive or capactive components. So the typically Prius battery is 1.5 KWH or 1500 WH or 1500 AmpVolt Hours. A typical starting battery is in the range of 600-800 AmpVolt Hours. Becuase the Prius 12 volt battery is only used in emegency situations then let's say it is only 300 SAmpVolt Hours. Thatt menas the Prius battery is only about 5 times as large as a normal battery in terms of true power: Killowatt or Ampvolt hours.
    The main reason that the voltage is inverted and increaste to 500 volts is because smaller wires can be used becuase the current is less.
    Powrer= current times volt times the angle between voltage and current (o for resistive, +/_ for inductive or capcitive) assume resistive.
    For example if the mote is a 2.5 Kilowatthour motor thatt menas the instantaeous power is 2500 watts or 2500 amp hours. If that is deliver by 12 volts then a current of 208.3 amperes while the same motor running 500 volts would only require a current of 5 amperes. The smaller the amperes or current the smaller the wire is need and the less loss due to impedence.
    P.S. - Were you awre the Prius can only go in reverse via the eletric motors. The ICE can not supply reverse power. Does that mean the Prius is a mild or soft hybrid in reverse?
  • "Were you awre the Prius can only go in reverse via the eletric motors. The ICE can not supply reverse power. Does that mean the Prius is a mild or soft hybrid in reverse?"
    Yes, I am aware. Prius ICE can not supply power to the wheel directly but it can power indirectly by generating electricity which then powers the main 50kw motor. Therefore, in reverse, Prius acts as a serial hybrid. Remember, the electricity generated from MG1 does not have to go through the battery, HSD can route power directly to the 50kw MG2.
    Dennis
  • nw1997nw1997 Posts: 227
    Can someone confirm this information. The cost to replace the Battery in the Prius is around $2,958.00. This is the battery that is in the trunk, in which is being constantly charged. The life expect. is 8/100K miles.
    The battery is modular and you won't have to replace all modules; the cost should be much less than $2958. The warranty is for 8 years 100,000 miles or 10 years 150,000 miles if you live in California. No one has any idea how long the battery will last; they just haven't been out that long and there is not enough statistical data gathered. Toyota has given people an ample warranty to alleviate their fears on this new technology. Anyone who says different doesn't know either and to play up to FUD (Fear Uncertainty Doubt) is not good forum or business practice.
    If Hybrid battery life is your only concern, then I wouldn't worry about it and would go ahead buy and enjoy the new hybrid technology.
    YMMV,
    MidCow
  • The Rochester Hills-based firm said it and Cobasys LLC, its manufacturing joint venture, had entered into a settlement agreement with Matsushita Electric Industrial Co., Panasonic EV Energy Co. and Toyota Motor Corp.
    The settlement was reached through arbitration. As part of the agreement, Cobasys and Panasonic will cross-license each other on current and future patents to avoid litigation.
    http://www.freep.com/news/statewire/sw100650_20040707.htm
    Let the number increase and the price fall !!!!
    Dennis
  • gagricegagrice San DiegoPosts: 28,680
    I seriously doubt the price of NiMH batteries will get significantly cheaper. Batteries of all kinds have gone up in price no matter what the rest of the Electronics market is doing. The only competition is generic batteries that have proven themselves inferior to name brand. At least in all the ones I have bought. If you are counting on the price going down by the time you need to replace the batteries, I would be real surprised if they are. Hopefully the generous warranty will take care of all your battery replacements.
  • " Batteries of all kinds have gone up in price no matter what the rest of the Electronics market is doing."
    Consumer electronic AA Nimh rechargable battery prices has been going down since it was introduced. Not only the price, the capacity had gone up as well. When they came out they had 1500 mah rating(higher is better). Now, they have 2400 mah batteries for less than what 1500 mah used to cost!
    Dennis
  • Yesterday during the chat, someone mentioned that NiMH batteries do not have memory effect. That issue needs to be cleared up in detail.
    Short answer: NiMH do have memory effect but at a very slow rate.
    Long answer: Compared to AA NiCD batteries, AA NiMH batteries suffers much less of the memory effect. AA NiMH retains/remembers 80% of it's capacity after 500 cycles. Hybrid Electric Vehicle NiMH batteries' memory is 20 times better. They have 10,000 cycles until it is reduced to 80% of the original capacity. That is to show the rate of the memory effect. The battery is still completely functional after that point. Replacing the pack is up to the owner if he/she wants to regain efficiency of a new hybrid car.
    Dennis
    All I know is the NiMH batteries for my Canon S10 camera are about 25% higher now than they were when I bought the camera 3 1/2 years ago. I bought a cheaper generic battery and it lasted less than 6 months. All batteries are not created equal.
  • The life of HEV battery should not be measured with the miles it is driven but under what condition.
    For example, during highway cruising, the battery is rarely used. Another extreme case is, short and hilly blocks in San Francisco with stop signs at every corner. The battery would use up plenty of recharge cycles in this situation, only if you accelerate hard enough so that the battery supply power to the main electric motor.
    Dennis
  • "All batteries are not created equal."
    Very true. More importantly, not all chargers are created equal either! It is the cheap charger that damages the battery by charging too fast and over heating the battery. Overcharging the battery when it is full also damages the battery.
    The charger in the Prius is very intelligent and powered by 32-bit CPU. There are temperature sensors to protect the battery pack with active cooling system. It is also packed with the latest charging technology to prolong the battery life.
    Dennis
  • djasonwdjasonw Posts: 624
    According to what I've read, the computers manage the battery drain and so forth. What really kills these types of batteries is draining them down completely. The Prius computer does NOT allow this to happen. I have practiced this technique with cell phone and laptop batteries and it seems to work. Gagrice is correct regarding generics, they stink!
  • rfruthrfruth Posts: 630
    - snip -
    The 30-kW Sanyo battery pack sits under the rear carpet and forms the cargo area’s load floor. Inside the thin metallic cassette sit 250 nickel-metal hydride D-cells wired in series and producing 330 volt. You read that right. D-cells,the same size as, but not interchangeable with, the ones found in flashlights. Unlike said flashlight, an external cooling vent in the driver’s side rear window is part of the forced-air thermal management system. In hot weather it draws excess heat away from the pack, while an electric heater warms the batteries when the temperature drops. Ford says the system can handle temperature extremes from -40°º F to +122°º F.
    http://www.autofieldguide.com/articles/070402.html
  • Each NiMH cell is 1.2 volts. If there are 250 cells, then the total is 300 Volts. The pack will need to have 275 cells to get 330 Volts.
    Dennis
    An example of new math or... I wonder if the Escape will use AC motor(s) or DC ?
  • robertsmxrobertsmx Posts: 5,525
    Why must NiMH batteries have 1.2V?
«13456733
