Can I use "regular" oil instead of synthetic oil?
recalcitrant
Member Posts: 13
How much would it harm a car to put "regular" engine oil in it instead of the recommended synthetic oil...
...if I did it just once?
...if I did it regularly?
Best Answer
carboy21 Member Posts: 760Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90
Won't guarantee but gives you a good chance to survive longer
I wouldn't let a Quickie Lube shop change the oil on my pressure washer!
I take my own oil and filter to the Jiffy Lube. Still works cheaper then dealership5
Answers
No way I'd do it.
However, since I posted my question, I did a little research, and I discovered that synthetic oil breaks down more slowly than fossil oil, especially at high temperatures, and that also, because of its consistent viscosity even at low temperatures, it provides good engine protection even when first starting the engine in extremely cold weather. So I can see synthetic oil is well-worth the added expense.
However, I'm curious about one thing: Does the above mean that an engine will run at a higher temperature in hot weather than it would when the weather is cooler?
"What's the best oil to use?
Ah, the million dollar question. We are an independent lab, so we don't make recommendations. It has been our experience that oil is oil, and either petroleum or synthetic-based oil will work well for just about any engine.
Come on, you're holding out on me. I should use synthetic, right?
Buddy, you should use whatever you want. Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90. We here at Blackstone generally use regular petroleum-based oil because honestly, it works just as well for us."
It's a black science. Or at least an amber one.
My 2011 Toyota Camry LE has a 2.5 L 4-cylinder (2AR-FE) engine, for which Toyota recommends SAE 0W-20 oil, which is actually printed right on the oil cap.
So that's what I'll use in the future.
