Best "Beginner Car" for Modifying/Tuning
Kirstie_HKirstie_H Posts: 10,989
edited May 2015 in Honda
Of course, the car you choose depends on what you want to do with it, but this topic will deal with the best choice or choices for the "first-timer", whether he/she is doing it to look good, just enjoy on the street, or to race in various types of motorsport.
Share your beginner success stories!
See Also: A Beginner's Guide to Modifying a Car
Share your vehicle reviews
«1
  • ajvdhajvdh Posts: 223
    If you want to build one of those "all-show-no-go" wanna-be touring cars, go with the cheapest Civic you can find. Those 18" rims and hundereds of lbs. of wings and bodykit are gonna sap what little performance you have anyway, and you're putting power through the wrong wheels, so why waste extra money on the bigger engine?
    If, on the other hand, you're interested in winding up with something that's big fun to drive, I'd go with a Miata. Decent 1st gens can be had for cheap, they have great handling right out of the box, and you can be competitive in SCCA solo events without any mods. If you want to hod-rod 'em, they're tough and straightforward little beasts and have a good-sized aftermarket, including all sorts of reasonably priced forced induction setups. I've run with some of them on tracks, they're very hard to catch. And if you're totally insane, a Ford 5-liter fits under the hood.
    If you want more serious track or autocross fun, C4 and early C5 'vettes are more money, but still can be had for reasonable bucks, and the SBC probably has the best choice of go-fast parts of *any* engine. But on a tight course, the turbo Miata guy will give you fits.
  • john500john500 Posts: 409
    It does depend on what you want. If you want to win street or track races using a street legal car with the least expenditure, get a Mustang GT. Almost all of the other vehicles will require an engine swap to be competitive with the GT.
  • carlisimocarlisimo Posts: 1,280
    I'll defend the Civic here a bit...
    (though I would recommend the Miata too, to people who can afford to have a non-daily driver)
    First off, it's a good daily driver. Four good seats, even in the coupe. Great manual transmissions. Great mileage if you shift early. Slow enough to teach car control more effectively. Good safety ratings for its class.
    Second, the pre-'01 models take modifications very well.
    Tons of suspension travel in the pre-'01's, and a high potential (well, theoretically) handling limit since the double wishbone front suspension doesn't lose its camber during body roll. They can be lowered a lot without hurting the car (though obviously, handling will suffer if the dampers don't match the springs). That's not true of the new ones; they have trouble if you change the suspension geometry and the only cheaper kits that don't do that are Honda's HFP and Mugen's SS, both of which are mild in drop and stiffness.
    And there are lots of parts (engines, most importantly) from other cars in the Honda line that drop right in. Easy to find the parts and people who can do the work. Lots of tried-and-tested aftermarket parts too, including turbos and superchargers, that are a bit cheaper than others due to the sheer volume of Civic sales.
    Third, you can tell people you're going to buy a Civic and they'll assume you're sensible, if a little boring.
    On the downside, Civics have had lousy steering feel ever since they got power steering. And a lot of people (here included) are sick of seeing them.
    Yeah, the 'stangs a good choice if you're after cheap, straightline speed. If your racing involves turns, you probably want to look somewhere else. The amount of time and work it takes to make a Mustang handle well is well beyond "beginner" status.
    And if you're racing on the street, then you're an idiot no matter what you drive.
  • driftracerdriftracer Posts: 2,692
    "The amount of time and work it takes to make a Mustang handle well is well beyond "beginner" status."
    That's a completely inaccurate statement, sorry. Not only is it easy to make a Mustang handle, it's pretty cheap, too.
    Depending on the year, I can give you a short list of products and changes - I made my 1986 GT pull .93 on the skidpad, using z-rated street tires, not slicks or Hoosiers, for under $1300 in suspension components and two weekends at my house.
    That's springs, struts, sway bars, bushings, braces (front upper, front lower, and rear upper) and a camber plate kit for less than the cost of a good set of coil-overs for a Honda.
    Skidpad firgures would mean something if all we ever did was drive in circles on perfectly smooth pavement. But the real world is full of transitions, increasing and decreasing radius turns, bumps and holes. The Fox/SN95's basic arcitecture is compromised for that kind of stuff. Ya see, I've owned one (t-bird turbo-coupe). I've also seen (and ridden in) quite a few of 'em both at autocross and as a road-course instructor. It's got roll center and steering geometry problems in the front. The 4-link rear binds up, and doesn't control the axle well.
    Yeah, you can slap big bars, springs and shocks on it, but you'll trade an increase in grip and better turn-in for really skittish behavior on bumps, and the snap oversteer the stock car already has will be even less predicable. Your ride qualtiy will suffer (kind of an understatement). Throwing out the entire rear suspension in favor of a three-link or Griggs setup is good start towards giving it the predictability and compliance it needs to be "good handling", but I'd hardly call that "beginner" level mods.
    If you want to explore good handling, why not start with a chassis that handles well from the get-go?
  • badtoybadtoy Posts: 368
    Choose the kind of car you want (60s mucscle car, 90s sport compact, etc.), and then pick the one with most aftermarket support -- that will almost invariably be the one that is reliable and responds best to tuning. Good luck! =D
  • spinzerospinzero Posts: 91
    You can weld your axles to the body and pull crazy G on the skid pad. To many, that is certainly NOT the definition of good handling.
    Even with cars that have independent rear suspension, once you slap on bigger anti-roll bar, you'll notice two things right away. One, you get more grip and oversteer, and two, your car will feel more nervous on bumps and during transitions.
  • fastsvofastsvo Posts: 26
    Guys,
    There are a lot of good potential cars out there. I honestly would look towards the Grassroots Motorsports Magazine GRM challenge cars as proof that you don't need a lot of money to get above average performance from a broad range of vehicles.
    But, if you asked for my vote, it would be the Merkur XR4Ti, Mustang GT, and the Mazda Miata.
    Eric Atoian
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,341
    Interesting that you chose the Merkur. That's kind of a devil to get parts for isn't it?
    MODERATOR --Need help with anything? Click on my name!
    It's not as bad as it seems, but there are definitely some parts that are no longer in production from Ford or are only available in Europe. But on the flip side there are many US vendors that have either imported or remanufactured parts for this car.
    Basically the internet will be your best friend for getting repair information and parts for the XR4Ti.
    Eric Atoian
    Thanks Eric for that info.
    I had a Merkur and really liked it except for I'd say that the engine felt pretty rough and noisy. But it was a lot of car for very little money, and once I squared away a few things, it ran and handled very well indeed. I'm wondering if that engine can be smoothed out somehow or if aftermarket mods have been made to do this---better mounts or an engine brace or something.
  • ateixeiraateixeira Posts: 72,587
    The Miata is easy to work on, they're abundant (half a million on the road), and even small gains in power are noticed. Strong aftermarket support, too. It's definitely up there on the list.
    Any SBC and Ford V8, too.
    Lately, Subaru WRX is a popular choice. Turbos are easy/cheap to tune.
    -juice
  • hondafriekhondafriek Ottawa CanadaPosts: 2,969
    Buy a BG series Mazda 323, slap a mazda GTX motor in (easy swap apparently)
    Intall ford ZX2SR struts with mild lowering springs, for not a lot of money you will have a little car that is so much fun and reliable you will smile every time you turn the key.
    Cheers Pat.
    Yup those 2.3li Turbo Ford engines can sound and even run like a tractor at times. Balancing the rotating assembly during a rebuild helps greatly and even stepping up to a 2.5li crankshaft will really smooth things out.
    Btw, I am really into the idea of owning an STi or even an EVO sooner than later. I believe the STi will be a great replacement for my SVO. Though the new Audi A3 and the new Charger SRT8 has my attention as well. As you can see I am all over the map for my next vehicle, but one thing is for sure, performance will be the major purchase motivator here.
    I don't think the engine was quite that big (2.3l). Wasn't it more like 1.6-1.8l or so?
    I do recall it was DOHC and turbocharged, but output was not all that high. But in a light car it would be a hoot.
    -juice
    I like the EVO better than the STi....both have some advantages over the other, but overall I preferred the EVO as a car I would drive everyday. I really romped on the STi and I got torque steer although other folks have said they didn't feel it on test drives. I think the STi is a tad faster but the EVO handles like a dream.
    Competition improves the breed - both have received upgrades regularly. The STi has quicker steering and a revised steering rack, I believe that was your biggest "like" when it came to the EVO. STi also got a wider rear track and the rear rims themselves are an inch wider. On top of that it gets a better front differential.
    EVO IX will get some tweaks, most notably more power, so these two really feed off each other. Ain't life sweet? :)
    -juice
    AWESOME cars...unheard of performance at this price range, say 20 years ago.
  • purrnakpurrnak Posts: 4
    I think for a beginner a crap car of any kind is a good start. I started with an '83 volvo that I got for pretty much free. It ran like a rock and after tuning and some scrounging for parts in a wreck yard I was able to get it up to 150mph... that might not be much for most, but this was an OLD volvo on it's last legs. It went for another 3 years after me and ended up with the person that owned it before me.
    The mods I did this this car were mostly sound oriented and just changing parts to newer ones but it was a great way to get my feet wet.
    I'm currently working on a Hyunday pony and I've added elwire, stearing wheel, stereo system, got the best spark plugs and points I could find, wired in a second battery and a buddy put in a system to detect when 1 battery is fully charged and switch the alternator to the other battery to charge (don't ask how it works, I have no idea)
    So the best car to work on for your first car, is the cheepest one you can get to get an idea of what can be done. I think anyway.
    My question: What can I do to my car to give it a bit more power? No fuel injections and it's a 4 cylindar. I have it tuned high so I can get off the line faster then most stock cars on the road.
    PurrNaK
    That's wild. And you were able to find spare parts without a problem? I'd be afraid of parts availability, lack of help from forums like this one, and the price of imported new-old-stock parts.
    You're brave. ;)
    Hyundai Pony - are you in Canada? I've seen those cars in other markets but not in the US.
    -juice
    A Hyundai Pony!!! where did you even find one of those? I thought they had all gone to car heaven. Geez those things rusted out even quicker than a Chevy Vega and that's saying something. :)
    Cheers Pat.
  • I need some help i have a toyota corona i have just replaced the points and need to know how far i am spose to set the it tis a 1980 toyota corona cs XT130e starfire engine
    I doubt you'll find anyone with information quite so specific. Do you have a Haynes or Chiltons manual for that model? That should have the specs.
    Also try a Google search for "Corona Specifications" or something like that.
    -juice
    The www.autozone.com site might have these specs.
  • HI I AM NOT TRACKING OR RESPONDING TO THE PREVIOUS DISCUSSION BUT AM WONDERING IF SOMEON COULD HELP ME OUT.
    WELL THE THING IS LAST YEAR MY PARENTS GAVE ME A CAR FOR GRADUATION, IT WAS A 2.0 GOLF, THEY DIDN'T REALLY WANT A CAR THAT WAS FAST, IT'S NOT LIKE I CAN BUILD A HOTROD WITH A GOLF BUT I WOULD LIKE TO TWEEK IT UP BECAUSE IT IS, HONESTLY STUPIDLY SLOW.
    WHAT CAN I DO, ANY IDEAS?
    That's what that engine was nick-named. To be honest I'm not sure there's all that much you can do to it, so I'd focus on the suspension, make it go fast around turns.
    -juice
    Yeah, that was not a good engine.
    Your options are to swap it out for a GTI engine, or to give it some forced induction. Given the ideosyncracies of VW electrical systems, it might be hard to make the first one work.
    Someone makes a supercharger for the base Golf engine. It doesn't make it fast though... I don't know if it's worth the money. Find some Golf experts, and look into the possiblity of using junkyard turbos and intercoolers.
  • m1miatam1miata Posts: 4,556
    Watch your oil. Those cars can use up to a quart per 1,ooo miles. The HP is plenty to learn on. Driver learning power first, cornering skills, and such, then more straight line power.
    -Loren
  • Well, as everyone has said, it depends on what you're going to do with the car.
    As for drag racing, the Ford Mustang is a cheap and powerful option.
    If it has anything to do with great handling, I'd go with either the Honda Civic, Mazda Miata, VW GTI, or a Dodge Neon for a cheaper, well handled option. If you have a lot of extra cash, the Porsche Boxter is an extreme, but quick, option. A few other cars tha tcould be useful here are the Nissan 350z, and the Subaru WRX STI.
    For street racing, any of the above are great options. I would go with the vehicle with the most aftermarket options, most likely the Civic.
    If you just want to look good, the 350z is a great looking car. The Mustang is a good lookign car as well, but it has more of a muscle-car feel, as apposed to the tuning feel of the 350z.
    -Jake :shades:
«1
Best "Beginner Car" for Modifying/Tuning — Car Forums at Edmunds.com
