Technical Advice for Mods andTuning
Kirstie_HKirstie_H Posts: 10,989
edited March 2014 in Chevrolet
In a jam about something, or would you like to share your solution to a difficult problem? Post in here!
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
Share your vehicle reviews
«1
  • would like to know how I might be able to make a 2004 Malibu engine more "efficient"? I.e. some more power without guzzling more gas.
    Suggestions, thoughts?
  • I have a 2004 Dakota. I am limited to Poweraid and Helix Power for my options for a throttle body spacer. Any suggestions for which one may be better? Two totally different designs.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,081
    Why are you using a throttle body spacer?
    MODERATOR --Need help with anything? Click on my name!
  • driftracerdriftracer Posts: 2,692
    other than slamming the warranty, I mean. I've tested lots of gadgets like TB spaces, velocity stacks, etc, and only MINOR gains have showed at ridiculous rpms (like 2 hp at 8,000 prm)....hardly worth the cost, and the warranty hassles.
    Also spacers suggest to me that something is not actually made to fit and work properly. The spacers can create obstruction or other flow problems into the manifold.
  • dharttdhartt Posts: 1
    how can you check the fuel system on a 94 gmc 4.3L engine? It isnt getting fuel.
    Wrong Board. Post that question here:
    Technnical Questions, Repair & Maintenance Boad
    MrShiftright
    Co-Host
  • wampa1wampa1 Posts: 2
    I drive a 94 Toyota Paseo, and its hard if not downright impossible to find any aftermarket parts for it. Recently I saw a Tercel of the same generation (1991 to 1995) with euro tailights. I would like to switch out the trunk and tailight assemblyon my car in favor of the tercel so i could have the euros, but i was wondering if anyone knows offhand or has the measurements for the trunk on a tercel of that yearso I can see if that is a feasible solution.
  • chevy11chevy11 Posts: 1
    I need to know how to down stroke a 350 with a 305 crank? any help would be apprieciated
  • eaglemtneaglemtn Posts: 1
    I have a 1988 Toyota Corolla SR5 Sll-trac with the 1.6L 4A-FE engine. I want to rip that engine out and put in a bigger one from a different toyota from about the same year, something more powerful, but I'm not sure what would fit. Of course when you ask Toyota themselves they say "we don't reccomend modifying our cars... blah blah blah." Do any of you have any idea, or know where I can go to find out?
    You need to take a trip to the wrecking yard I think (maybe a Pick a Part type operation) and bring some brown wrapping paper and a magic marker and make a pattern of the tercel taillights (which will probably be removed from the wreck anyway, so it'll be easy). If the Tercel assembly is larger than maybe you can get away with some careful cutting to make them fit the Paseo (a handy tool for this might be a "nibbler") but if the Tercel assembly is smaller that sounds like a lot of work, as in welding.
    You might check to see if Toyota actually upgraded the All-Trac engine at any point; if they didn't, I don't think such a conversion is worth the trouble--you'd be better off modifying your engine or at least doing an overhaul on it and then a turbo kit if you can find one. But trying to stuff an engine that was never meant for that car could be a hell of a lot of work on an AWD car especially.
  • eriknoxeriknox Posts: 1
    Me and my wife just decided on buying a crysler crossfire and I am looking for more speed and not wanting to pay the extra $15000 for the srt. I have looked and looked on the web and found nothing. Any suggestions apreciated.
  • I recently purchased a 1989 GMC R2500 Suburban with a 454. Most of my experience is with classic Mopar vehicles. That said, I would like to get some suggestions on what I can do to get this bad boy running at its best. I noticed that it only has a 2 barrel (fuel injected) carburetor. Is this the best way to go (again, bear with my in-experience)? I also noticed that it has single exhaust... what an injustice :-) What type of manifolds/exhaust performs best with this type of engine?
    Oh, any other performance enhancing suggestions would be greatly welcomed.
    I always like to think of the intake/engine/exhaust as "one long tube". So if you do something to one end, you need to be thinking about the other end. I think dual exhausts (with the proper exhaust headers) would be a good idea on the "back end", and you might check and see if intake vendors like Edelbrock make anything that would work on your '89. You have the TBI injection type, I think and I don't know how much you can do with them. Also you don't want to run into smog hassles or do you care?
    How fast you want to go depends on how much you want to spend. Simplest mods are getting more air into the engine (such as cold air intakes or short ram intakes) and a free flowing exhaust. Probably the stock ignition is good enough for your needs.
    Here are some good books on seriously modifying the 454:
    http://lib1.store.vip.sc5.yahoo.com/lib/rodi/guide.hpbooks.app1.html
    But I think a custom air filter system and dual exhausts would be a good first step for you.
  • runs great.when warm/hot after sits,won't start.engine turns over seems to be getting fuel.help
    You should post this question in our Maintenance & Repair Board. Look for the topics called "Technical Questions" or "No Starts".
    MrShiftright
    Co-Host
  • 350 chevy with headers and flowmaster's. what all could i change out to give it HP or just better preformence? like the coil distributor, wires, alt. really i dont wana make a hotrod but i just wana fix it up better than stock. I wana change parts that it has just to newer and better ones. like a 45 amp Alt. to a 55 Alt. i need ideas!! anyting will be helpfull. Elderblock carb. intake. headers , flows, hot plugsnew oil and filters, i have done thus far. Thank you
    this is a big subject....I think if you are fishing for ideas you'd find these books very helpful---they'll give you some gameplan.
    Small Block Chevy Books from Amazon
  • I just bought one and have the same problem. Cant find anything on the net.. there is however an option with Powerchip. They can chip the engine which gets your about 15 more Kw and 40ish more Nm. If you find anything else, please let me know
    Simon
  • bigjoe1bigjoe1 Posts: 2
    I need any and all help modifying my 2002 3.4L Impala. NO matter where i turn, i can't find parts to make it faster or anything. it seems they only make parts for the 3.8L. if anyone can help, please do.
  • bjs77bjs77 Posts: 2
    I got new tires (taller) and need to recalibrate speedo. Are there any pprogrammable modules that have preset programs? I want to improve mpg before taking long road trip. Any suggestions. Thanks
  • Hey there folks! Just got my 2005 Victory Red 2500HD Crew Cab 8100/Allison today. And im already looking for aftermarket things for it. Im planning on putting two 26 in Hadley and two 24 in Hadley airhorns on it, true dual exhaust and maybe a superchip.
    First off, what exhaust system should i use? I'm thinking about getting two flowmaster series 40's (I want a very deep and loud sound coming from my big block monster) I hope to announce my coming with those, and then to reinforce it with the 4 air horns.
    I have been looking at Superchips, but im not sure if i should do something like that. Will it damage my engine any, and what kind of power gains should i get. 330 hp to maybe 360? 450 torque to 500? Tranny damage doing something like that? (i wouldnt think so since the Duramax makes 605 torque but im not sure)
    and also my truck has the towing package which puts option k47, the high capacity air cleaner on. I have always used drop in K7N filters before this truck... should i with this one?
    I think Flowmasters do a good job but keep in mind that you could grow very very tired of the noise if you pick a system that is too non-restrictive. But maybe given what you are driving you are fairly noise tolerant? Anyway, it would be great if you could take a spin in a truck similar to yours that has already done this. I wish I could give you a heads up but I don't know anyone who's done this on the Duramax.
    You want 10% horsepower increase from a chip? I don't think that's realistic. Have you seen such claims? Let us know with a URL and we'll check it out.
    As for air filters I personally think simple "drop in" filters are useless---you'd need to consider a ram effect or cold air intake to get anywhere I think.
    Anyway, the air horns sound like a great idea (I wish I had some for my Porsche) and the exhaust setup may work out really great for you---wish I knew more about that particular application. We need to do some homework, right? But I'd wave you off the K&N and as for the superchip, this needs research--there's a lot of stuff out there that just doesn't deliver as advertised.
    Maybe you could work out a deal where you buy the chip and dyno it yourself, and if it doesn't show what it's supposed to, then return it and get your money back. You may lose the dyno fee but at least you haven't blown $300 for nothing and maybe even a LOSS of power or fuel economy.
  • i recently purchased a 2005 celica gts, and i really love the car. i plan to turn it into a street racer but i have a few questions first. it is a real chore to find parts for a 05. are parts like a cold air intake, cat back exhaust, coil overs, and turbo kits interchangable with the 03-04 celicas and the 05 model. all of the companies only sell parts for up to the 04 model. any help would be greatly appreciated. thanx. jc
    Have you checked with TRD yet?
  • Thanks for the input... im very tolerant of the reverberation so i think i will be ok with that. (i had a 79 ford 351 with no exhaust on it... that was loud, but it didnt bother me) (that truck also had two 26 inch hadley air horns on it... they were really dern loud... so 4 should be even better!)
    On the old superchips page they claim that the 8.1 liter V8 should... or maybe they should say could get about 30 extra hp, and 40 extra ft. lb. of torque. I called them to speak person to person and he told me the same thing. (i think expected gains would be hard to really concretely say, but i like the idea of 30 hp and 40 ft. lb, for that. what do you think?)
    Well what's the guarantee. Will they guarantee the truck will dyno out an extra 30 HP? do they mean at the flywheel or the wheels by the way.
  • mmoyermmoyer Posts: 5
    I have a 99 Sebring convertible and would love to get 20 or 30 more horsepower. Any suggestions? Including things other than an aftermarket chip.
    By the way, the 99 is a 2.5liter, 168 hp
«1
Technical Advice for Mods andTuning - Car Forums at Edmunds.com
