mustang 1996 gt 4.6 sohc / cobra 4.6 dohc swap ?
gavingriswoldgavingriswold Posts: 2
edited May 2014 in Ford
What would I have to do to swap the stock sohc 1996 mustang gt to a dohc engine . I have the complete car for parts ? Thanks . G.
  • 82boss82boss Posts: 3
    I would belive that it would fit just fine without any mod's done to the engine bay do to the fact that there both 4.6 Ltr's however I have heard alot about the dohc's not really putting out without giving you headaches in the end. The way to do it is to port and polish that head and monifold if the manifold is aluminum at least, and do some head work new spring's lock's roller's and the whole kit can be picked up for a little over a hundred bux if you do your shopping right, then drop a good cam. Check out some other online forum's but if you just want to do the entire swap it should bolt right up...
  • s14slides14slide Posts: 1
    yeah, that's great that you have the whole car for the swap. Ensure the computer is in good working order, but other than that, you might have to swap or slightly modify the wiring harness here or there. There should be a lot of info about this on Ford mod engine specific forums. Now gets to the researching and let see a GT sleeper come to life!
  • cpeekcpeek Posts: 2
    talking a lot of work for your muscle car, but I think it would be well worth it!
  • I'm currently putting a 97' Mark VIII 4.6 in 97' Cobra and I had to do was to change the wire harness,intake,valve covers. The most important change was the Mark VIII 6 bolt flywheel from the 8 bolt flywheel 5 speed Cobra tranny. I bought a 6 bolt kit(Mustang GT) and made the conversion.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,775
    Do you think keeping the same year for both (1997) made things a lot easier for you?
    MODERATOR --Need help with anything? Click on my name!
mustang 1996 gt 4.6 sohc / cobra 4.6 dohc swap ? — Car Forums at Edmunds.com
