2000 Dodge Ram 1500- Rough Idling Problems
crh2crh2 Posts: 1
edited March 2014 in Dodge
I have a 2000 Ram 1500 Quad Cab (3000 miles) with
the 5.9 V-8 (Gas). I have had it in the shop twice
the dealer agrees that it is idling rough but
showed me to other new trucks on the lot that had
the same miss while idling is this normal ???? Also
a noise with the Air condition compressor while at
very slow speeds... Any help with be appreciated
  • 4daughters4daughters Posts: 24
    OK here I go again. Perfection in motion but this time it may be legitimate. On my 4X4 Quad, Auto, 4.7L, when I go to use the intermittent wipers I get more of a sporadic delay. No matter where I put the switch, slow delay or fast, the wipers go on and off at their own discretion. Does anybody else have this? Here in (Western) Washington State I am in great need of this feature and for it to work correctly. Does this thing have a "rain" sensor that needs turned off?
    Oh by the way, the whining going on under the hood, after some study, is only happening during cool/cold days. The truck sat on a warm day for 8 hours once but upon starting it and driving off I never heard the noise. But again the next cool morning it was back. ??
  • bpcambarbpcambar Posts: 1
    I have a 2000 Ram 1500 Quad 4x4. I have only owned it for about 2 weeks. I had a phone installed today and they called me and said that the pad under the carpet on the drivers side was soaking wet. I checked it out and sure enough it was dripping wet. There is no visible water damage on the carpet. It rained here 2 days ago and this is the only time that it has been around water. Has anyone else had this problem? If so will they replace the entire carpet? Also, how much time do you have before you can return the vehicle to the dealership and tell them you are not happy with it? Is there a time limit??
  • flobossfloboss Posts: 1
    I have a '98 Ram 1500 4x4 with the 5.9 liter engine and have had a rough idle from the day I took delivery. I, too, drove another '98 Ram and it had the same problem. It appears that most, if not all, have it to some degree.
    The mechanic who looked at my truck supposedly talked to a Tech. Rep. at Chrysler whose response was that the emissions had been tightened up for the '98 trucks and that was probably the reason for it. The Tech. Rep. said that if they received enough complaints, a service bulletin might be issued on it. So, my only advice to anyone who has this same problem is to keep complaining to your dealer as I have, and maybe enough voices will get the problem fixed, if a fix is possible.
  • fury126fury126 Posts: 1
    For those of you with water leaks, I have a '94 Ram reg. cab. I had 2 separate water leaks, both of which were caused by a defective rear window. My original rear window let go 2 months after I bought it. A pinhole leak around the rear window seal. They fixed it, including replacing the carpet (as it was soaked!) The second time the rear window leaked was just before the warranty was up. This time my headliner as well as my carpet and window were replaced. The body shop tech recommended an aftermarket window with a metal frame, this seems to have fixed the problem (knock knock).
    My idle problem is when I let off the gas and it is cold and/or damp. The engine almost dies (sometimes it has) I tuned up the truck (it only has 22,500 miles) and this took most of the flat spot out, but not all. Next time I am buying a Toyota or Nissan crew cab.
  • klm1962klm1962 Posts: 6
    Engine miss?? way!! I have had an engine miss/rough idle since day one. Also in the V-6 SMPI motor is what Daimler Chrysler calls a normal characteristic of this motor. I have an engine vibration between 1000-1500 RPM. A vibration or out of balance condition will cause premature engine failure. ie; crankshaft will break in two, camshaft, thereby damaging the other internal components as well. Hopefully it won't happen to me as I travel to work on I-40 and a large truck is behind me. Lots of squeaks and rattles and no customer service what-so-ever.
    If anyone else has the Ram 1500 with the V-6 please post a reply to this or e-mail me at
    As I stated up above in a previous posting, I too have an engine miss and rough idle in the V-6. I test drove several V-8 trucks as well and ALL of them experienced the same symptoms. Chrysler states it is just because of tighter emissions. BS I have driven Fords, Chevys, and without any motor vibrations, rough idle, or engine miss. They probably define the problem as a "normal characteristic" of this motor....correct? Just because everyone of the motors has the same problem DOES NOT MAKE IT NORMAL !!!!! They have serious problems with their onboard computers and will not recall EVERY ONE of them for repairs. Your best bet is to keep on them about it. IT IS NOT NORMAL!
  • davids1davids1 Posts: 411
    When is this miss occurring? My '99 1500 quad 4x4 with the 5.2 liter bogs down on the 1/2 upshift right after startup. This is the only strange characteristic of my motor, at least up to this point.
    The miss is occuring at idle, and while driving. What you seem to be experiencing is a problem with the transmission not shifting properly. Does your truck idle rough?? Is there a "ticking" noise coming from under the hood?? If so then you probably have a "miss" too.
  • elborachoelboracho Posts: 1
    I have a '00 1500 QC 4X4. The truck I bought, plus two others that I test drove at the dealership, all idled roughly. The problem seems to lessen after the truck warms up, though. Has anyone tried using premium gas or some kind of additive and had any success in smoothing this problem out?
  • wwhite2wwhite2 Posts: 535
    Do not try premium gas or "mechanic in a can" to fix rough idling problems you are just wasting your money! Why would you buy a truck that idles poorly ?
  • rrichfrrichf Posts: 212
    Does the truck still idle roughly when you shut off the A/C ?
  • MercuryNJMercuryNJ Posts: 8
    The wife has a 1995 Dodge Neon HL, that she bought brand-new in April '94, it began to idle roughly after 2K miles, she took it back to the dealer and was told that the oxygen sensor had to be replaced as per TSB and diagnostic code, they replaced it and the Neon has never had rough idle ever since.
  • spinnyspinny Posts: 1
    I have '00 quad 2wd with that nasty idle problem also. So far, they have replaced the intake manifold gasket, (improvement), then they replaced a air/fuel motor (no help). Morning starts, and quick start and go seems to be the most aggravating conditions.
    Anyone worked out lease and lemon law together?
    Just bought this truck in March, with a 3yr lease.
    Highly disappointed!
  • Having serious problems with my Dodge at 30k miles. Bought my truck used with 16k and had problems ever since. 1st notice a clinking sound,it was missing and then the cruise couldnt hold speed. Going up hills it would go out after the first hil and refuse to shift down on all the rest. Took it in and they replaced the catalytic converter because they said it was falling apart, replaced all the other usual stuff fuel filter pump etc. Changed the cruise servo.. Latest problem is the cruise still wont shift down and now it shuts the AC off while going up hills. So now going on the 5th trip in less than a year to dodge to now tell them that their latest fix to curb the AC from shutting off isnt working. Anyone having this problem and did you ever get it fixed? Thanks
  • wc27wc27 Posts: 1
    2001 5.9L with 3000 miles, dealer told me it was normal for my truck to idle rough,,,,yeah right!!!!
  • nrd525nrd525 Posts: 109
    Well,I have owned THREE 360(5.9)powered vehicles,ALL of them had a slightly rough idle.This seems to be something they develop.My 74 Roadrunner had it,it was fine,never had any engine trouble.My 77 Power Wagon was a disaster,but not due to a bad idle.Everything else went wrong though.I had a 79 Ramcharger for a couple of days,it looked ok at first,then I put it up on a lift,and found out it had been wrecked and salvaged.I got my money back on it.It shook just like my Power Wagon,and my Roadrunner did.
    KLM1962-As far as the 3.9 goes.It's a "crude" V6,just a 318 with 2 cylinders whacked off.Just like the 4.3 Chevy V6.It's NOT GOING TO IDLE SMOOTHLY.My 88 S10 Blazer shook at idle,like they all did.The GM engine has balance shafts now,and it's a lot smoother than it was.The Dodge 3.9 doesn't have balance shafts,and has the old shake common to ALL these "designs".The original Buick 3.8 V6 was the first of the hacked V8's and it shook until they redid the crank(offset journals),and put in balance shafts.ALL these engine were was just a really CHEAP way to make a "V6" from the tooling they had for smaller V8's.The Buick 3800 is by far the most advanced of these designs,the Dodge is the least.
    I have to ask,what wee you thinking when you bought a 3.9 Ram?I don't know how anyone could actually buy one.I couldn't take a 3.9 in a Dakota,let alone a Ram!I'm not trying to get you angry,I just don't understand it.I've had a couple of "lesser" powered vehicles in the past,and after a few years,I really hated them,and was happy to see them go...
  • jarndt1jarndt1 Posts: 11
    I recently purchased an '01 Ram Quad Cab SLT 4X4 SWB with a 5.2 V8 and a 5spd. I too noticed the rough idle problem right from the beginning. The small block mopar V8's available in the Ram date back to the 1950's when they were designed. They are now computer controlled, CNC machined, and fuel injected, but the major mechanical parts comprising the engine haven't changed much over the years. It is an OLD design and Chrysler knows it. They have stretched its emmissions capabilities as far as they will go, maybe a bit too far which could very well cause a rougher idle than would be otherwise. THAT is why a new engine lineup is in the works due to be introduced within the next year or two. The 4.7L V8 in the Durango is the first of this line. Ford and Chevy have already introduced their new engines, retiring the old designs to make way for tighter emmissions requirements. If you have paid close attention though, you might have noticed something interesting. The new engines reach their peak hp and torque at a much higher RPM than the old engines and Dodge's Magnum series. In addition, Chevy's 270hp rating for the larger of their small V8's is a bunch of BS. Several dyno studies have proved it is in fact much lower. Lower than Dodge's conservative 245hp rating on the 5.9L Magnum. I don't wish to start a war with anyone, but personally, I like the older design better. In fact, I bought my Ram when I did to avoid having to buy one with a new engine design. The old 5.2 and 5.9 pair are tried and true, strong, and reliable engines. I want my hp and especially torque down lower in the RPM band where I can use them, not up over the 5K mark. The Chrysler Corporation is not the bad guy here, they are just trying to make the most out of a very good product. I'm sure they knew about this problem back in '98 when the emmissions restrictions were tightened. They probably simply couldn't make the existing engine burn any cleaner without sacrificing some form of performance, in this case the idle. Just trying to shed a different light on the problem.
    Ram 4x4 X-cab with the 5.2 liter had the rough idle. My current '99 4x4 quad w/5.2 also has the rough idle. The rough idle occurs only at after a cold startup. This is a feature (not problem) I can deal with rather easily. Those of you interested in a Ram should know that the cold start rough idle is a characteristic of the motor and not a problem.
  • cdeancdean Posts: 1,110
    I've said this other places but, to point, I have a hard time believing GM or anybody can 'fake' horsepower ratings.
    Please show us these 'numerous' dyno tests. The only tests I've seen is the Truck trend Chassis Dyno, which shows rear wheel hp, not actual engine.
    And the interesting thing about that test was it showed the Chevrolet about 40 hp behind the Ford--a lot. But then Motortrend took the same engines and loaded up with 800 lbs and the Chevy outran the Ford. How can an engine with 40 less hp outrun another?
    There are no 'facts' in this arguement.
  • jcmdiejcmdie Posts: 595
    The ford was 3.55 rear end and I believe that the chevy was 4.10. That is how 40 HP less can accelerate faster. For some raeson the mags never get comparable trucks to test.
    The Chevrolet was a 3.73 gear and the Ford was a 3.55.
    Even if it was a 4.10, it would not make up a 40 hp delta. horsepower is speed rating--which is why acceleration tests like that are good proving grounds for. that tests shows engine performance thru the entire rpm range, which kinda equals out ESPECIALLY with the flat torque curves of today's chevy and ford engines.
  • I bought a new 99 ram 1500 quad cab, The biggest mistake of my life . what a piece of junk! at 18000 miles it left me stranded in s.c. for three days while the Transmission was replaced.( with a used rebuilt one.(dodge would not pay for a new one). Also at 19000 miles engine was torn down due to using a quart of oil for every tank of gas. They had to replace the intake manifold gasket. Also have neumerous electrical problems that have needed to be repaired. anyone looking to buy a new truck don't buy a dodge. (my dealers response to all these problems is We don't make them we just sell them! There customer service is as about as good as their product JUNK!.
  • jdkan1jdkan1 Posts: 1
    I am reading these responses to all the Dodge truck owners with "problems". My question is what in the heck are you talking about? Maybe you live up north where cold weather affects your idleing? I have Been a Dodge owner for ten years. My first Dodge truck was a Ramcharger with the 318 (5.2 Ltr). I currently own a 1998 Ram Quad Cab with the 360 (5.9 Ltr). I had the Ramcharger for eight and a half years, put well over 100,000 miles on the engine, all I ever did was my normal maintenence like oil change, tune ups, etc... My '98 Ram has had new tires and brakes, and I change the oil every 3,000 miles religiously. No problems with Dodge trucks yet. Then again I drove commercial tractor/trailer for seven years, and I understand trucks a little more and have a some common sense about most things. I am not stuck to one particular manufacturer, I just like to stick with things that work for me. My truck has no "idle" problems, and it is much more powerful than my old "throttle body" injected 318. Sometimes I forget I am driving a pickup truck, it rides that smooth! Oh, I have 44,500 miles on my'98 right now. As for torque, that is what pulls, not horse power. The lower RPM you can get your torque, the more you will be able to pull. I have driven All makes of big diesel engines, Cummins, Detriot, and Caterpillar, and most of them were six-cylinder engines with huge huge foot-pounds of torque at low RPM's. I thing the Biggest truck I ever drove was a 1994 Freightliner, and it had 350 Horse Power, that's all! But the engine produced about 1,250 foot pounds of torque. That's how they pull 80,000 pounds. That is what I want out of my Dodge Ram. Lots of Torque, and my 5.9 has delivered (rated @ 335 Ft. Pounds of toruqe). But, it sounds like everyone on here dislikes Dodge, but if you have problems to that extent, buy something else. I had a similar problem with a Ford product (wont get detailed) and it was the first and last Ford I will EVER own.
  • I have my first & last Dodge Ram ( 1995 ).
    I have had uncorrected vibrations since day one on 70 mph highway driving. The brakes are undersized and in the winter the windows will not go down with the slightest moisture on them. Also at 100,001 miles ( policy I bought was for 100,000) the air conditioning died. $1,200 to fix. Plenty of rattles to keep you company.
  • phatdanphatdan Posts: 2
    My Ram ha 43k on it and has idled rough when cold evry morning since I drove it off the lot. Been a good truck other than 4 intake gskts and constant pinging( which has been fixed thanks to a new "flash" from Daimler-Chrysler). Would like help on a new problem which has just started. Bad vibration at 40mph and up. Feels like misfire or road bumps. Have installed new plugs, tires, shocks and still have the problem. Local dealer did the portable computer thing and came up empty. I drive 100 miles a day and am starting to get irritated.
  • merchelmerchel Posts: 1
    just bought ram 2 weeks ago and it has a major idling problem. i took it to the dealer to get it fixed and he said theres nothing wrong with it and that its a problem with all the 2000 rams. i asked to sit in another one and i sat in a 2000 ram v-8 and 2001 v6 none idled neer as rough as mine.i really thing somthings wrong has anyone had there idling problem fixed yet!
  • kamel51kamel51 Posts: 1
    At 1,700 miles my brand new 2000 Dodge ram 4x4 started a rough idle. I shrugged it off until one day it chugged and missed between the 1st and 2nd gear shifts, I have a 5-speed manual with a 5.2 V-8. It has done this just about every day. It only does it at start up when it sits overnight. I also noticed that it is worse if it is damp out. Had it to the dealer twice, waste of time. 1st time they said it was probably bad gas or some additive that was put in the gas. I have (3) other vehicles that I buy gas for from the same station. When the service man went to work on my truck he also did the portable computer check and it did act up for him, but he couldn't figure it out. 2nd time at the shop they said there was nothing wrong. It still idles rough, jerks between 1st and 2nd gear but I hate to keep taking it in for service when they don't find anything wrong. Other than this problem I can't complain about the truck. I get 19-20 miles per gallon at 55 - 60 mph and I have the off road package with the 4:10 rear end, and this is no BS.
    Some vehicles are more susceptible to moisture/condensation in the fuel system. Try a safe, non-corrosive fuel system water remover. I tried this in my 97 4x4 Ram club cab and it did seem to help. Let me know if it works for you.
  • bobw14bobw14 Posts: 1
    I am considering a 2001 4X4 1500 w/5.9L, Has anybody out there purchased the Offroad package? My question is whether it really provides an additional 2" of clearance. If it does than in theory, you should be able to put 33x12.5's on with the stock suspension.
    Also, can anyone recommend a good dealer in San Diego? How much over invoice should I expect to pay?
2000 Dodge Ram 1500- Rough Idling Problems — Car Forums at
