Nissan Maxima vs. Toyota Camry
m183837m183837 Posts: 1
edited April 2014 in Nissan
I am trying to decide between the 2006-07 Nissan Maxima or the 2007 Toyota Camry XLE.
The car I choose will be equiped with all the bells and whistles.
What are your recommendations, should I go for the Camry or the Maxima?
«134
  • lmacmillmacmil Posts: 1,756
    I suspect the Camry V6 will get several mpg better mileage, at least on the highway. Check the Maxima turning circle, Consumer Reports says it's 44 feet which would make for a lot of turns in tight spaces. Apples to apples equipped, I think the Camry will be a little cheaper. The Maxima, otoh, is perceived as being more "upscale."
    Both will be very nice vehicles. In the end, only you can decide which one is best for you.
  • tristan1tristan1 Posts: 39
    I just bought my wife an 06' Maxima SE a week ago. I test drove bought Camry SE V6 & max SE. Both cars pulls the same but the handling on the max is tighter for it's size. Max has a bigger interior. I like the memory seating too. But the max price is higher than the camry. Camry has a better MPG. Camry has a voice activated navigation. Bottom line is test drive both and see the difference.
  • blindmantooblindmantoo Posts: 139
    We traded in our Maxima for our new V6SE. My words of wisdom are to check out the Edmunds Maxima forum and Consumer Reports vehicle history reports for the Nissans. You'll end up with a pretty cool car w/ lots of features - but you'll get to know the Nissan service dept much better than you ever wanted to. I guarantee you'll know everyone by name in less than a year.
  • suydamsuydam Posts: 1,707
    We bought our Maxima in 2001 over the VW Passat partly because Consumer Reports rated the Maxima highly for reliability. We haven't been sorry. In 5 years the only problem it's had was replacing brake rotors (just a month ago) at 60,000 miles.
    That said, the two vehicles will drive quite differently. Drive them both and see which appeals to you. Is the turning radius on the Camry that much different?
    '14 Buick Encore; '13 Honda Accord EX-L
  • mf15mf15 Posts: 158
    If you can wait until November look at the 07 Altima, it will be better than the revamped Max. Old Mike
  • maximafanmaximafan Posts: 592
    One thing I've noticed when reading about
    the problems and solutions section of Edmunds
    forums on the Maxima is that most of the
    questions relate to Maxima's that are almost
    ten years old, with a few exceptions. I
    don't know. To me, that's a pretty good
    indication of some good reliability. I mean,
    things are bound to happen on a car that's
    over 7 years old. Even the 2004 to current
    Maxima's don't seem to have a whole lot of
    problems, except for the recurrent vibration
    issues. And the 2004 to current Maxima is
    made in the USA. So, I'm trying to still
    keep an open mind about the new Maxima and
    even the new Altima, due to my positive
    experience with my 2002 Maxima.
    I would like to wait and see if any issues
    come up with the new CVT trannie in the 2007
    Maxima. Just my two cents!
    I forgot to ask you in the previous post,
    what year was your Maxima?
  • patpat Posts: 10,421
    Just for future reference - lots of folks miss the fact that you have about 30 minutes after making a post to either edit or delete it. ;)
    Ours was a 2000. Had a "serious driveability" issue when new (only on the 5sp manual tranny cars). Nissan denied that it was an issue - when in heavy traffic at about 10 - 15 mph the rpms would drop out suddenly. If you simply pressed down on the gas pedal nothing happened. You had to let off, then press down and the car would lurch forward. You could re-create the problem 100% of the time. "That's normal for this car" was the answer. Finally I found a dealer w/ a master mechanic that took it on as a "pet" project. He worked w/ Nissan engineers to finally solve it - after eight trips to the service dept.
    The rotors were replaced at 19k miles, the Oxygen sensor died at 25k (killing a trip to a friends surprise birthday party). I had to limp back home on the highway for two hours at about 25mph. One ignition coil went - so all six had to be replaced at about 40k miles. The drivers outside mirror worked some of the time from about 40k miles until I got rid of it. The drivers power window would go up, then bounce halfway back down when closed w/ the auto up feature for the last two years. The leather on the drivers seat started wearing through at about 12k miles - Nissan called it normal wear & tear. If a bug, sap or bird droppings sat on the paint for more than six hours, it killed the paint (black car).
    One rear rotor locked up at about 75k miles. Nissan wanted over $1,000 to replace the pads, rotors and calipers - A local independent did it for a mere $650.
    I'm sure there was more - I just can't bear the memories. Yes - the car looked good (black w/ beige heated leather, SE pkg, Bose, Moonroof, etc. It was fun to drive - except for the awful turning radius - always took two manuvers to get into a parking spot (Camry & Odyssey are way, way better with tighter turning radius).
  • jeep1999jeep1999 Posts: 6
    I'm in the thinking stage about whether to purchase a new Camry or a new Maxima. I've been doing some research about both cars on Edmunds. I like the styling of the Maxima but I also like the new design of the Camry. I would give a little edge in reliability to the Toyota product. I would appreciate any comments anyone might have as to which car is the best for the money overall.
    I know it comes down to personal choice but any comments would be appreciated. Thank you.
    Thanks, Pat. I forgot about that. I have
    to remember to check the "Recent Messages"
    and even when I do that, it takes me back
    to the top of where I was on the "so-called"
    page before and I have to scroll all the way
    down again. Usually, what happens is if I
    don't see any recent replies near the bottom,
    I assume there is no recent posts. But I'll
    remember the "30-minute" edit rule.
    Thanks again.
  • 210delray210delray Posts: 4,722
    Front & side impact tests:
    Maxima
    Camry
    Note that the prior generation Camry with side airbags is superior to the 2004-06 Maxima. For '07, side airbags are standard in the Camry, and the car do at least as well.
    I just had a general question for anyone out there. I have a 2001 VW Jetta that I'm thinking of trading in for a new car. I still owe about $9,000 on the car. Would the dealer give me a portion of what the car is worth minus what I owe on the car? This is my first trade in and I'm not sure totally how it works. Thanks for whatever help you can give.
  • mfletou1mfletou1 Posts: 508
    The dealer will buy your car, literally, from you, and then pay off what you owe and apply the difference to your new purchase.
    I rented a Maxima for a few days, and now I drive a 2007 Camry. I'm sure I would have gotten used to it SOME but I found the Maxima VERY difficult to live with. The turning circle was ridiculous---I suppose once you are aware of it, you adjust, but I had to pull a u-turn that would have been easy in any other car I had driven and I nearly got killed because the Maxima didn't make it. There is a lot of room in the back seat and it has some neat features.
    But I think the feel of the controls and layout design are better in the 2007 Camry, and I think you'll find it quite a bit more nimble. Mine is a hybrid so obviously the Maxima is much faster, but the V6 Camry is pretty quick also.
  • pernaperna Posts: 533
    This is ridiculous. The Maxima is one of the most reliable cars you can buy, bar none! SUre, there is the occasional "my headlights were stolen" or "My 1991 Max won't start", but for crying out loud. Cars are machines, they aren't meant to last the owner's lifetime*!
    *unless they're Buicks :P
    Thanks for the tip. I still think Toyota's reliability is better than Nissan. We are seriously condsidering buying the new Camry over the Maxima. Granted the Maxima is a very sharp looking sedan. The new Camry is also very sharp also compared to the older models. Good luck with yours!!
    I hope you have it for a long time without any major problems.
    I agree with Perna whole-heartedly. I've
    been perusing these forums on the Maxima problems and solutions reading back two or three years, and it seems that most of the questions involve Maximas that are anywhere from 5 to 11 years old. You're bound to have some things occur on a car that's over five
    years old. Yes, there are some newer Maximas
    from the last couple of years that have had a
    few problems, but it still doesn't add up to
    anything more scary than the well-known problem
    with the 2007 V6 Camrys with the transmission issues.
    Unfortunately, my 2002 Maxima was involved in
    a wreck Monday evening, so my car my be totaled
    out. It's been a fantastic car! The 2007
    Maxima will still be at the top of my list to
    consider when I get ready to shop for my next
    car.
    I sat in an '07 Maxima... very, very nice. They did fix a lot of the things that bothered me with the '04-'06 models.
    Hope everything goes well with the insurance companies.
    Notice how they TV ads for the new Max talk about "shift bump" while extolling the virtues of a CVT. Show me a late model car with an objectionable "shift bump" and I'll show you a car with a poor designed transmission. I think they should have tried a different angle for that ad.
  • troetroe Posts: 1
    I have extensively researched the 2007 Nissan Maxima, 2007 Honda Accord and the 2007 Toyota Camry. I plan on buying one of these vehicles with the works. A few of the Internet tools I've used to help me narrow down my decision are Edmunds, epinions, and consumer reports. I can't remember which site directed me to an article by the Gadget Guru, but it was an in depth article on the Camry's navigation system and to beware. Because I so badly want GPS in my next vehicle I may still buy the Camry, but I will be sure to go with an after market GPS instead.
    Was that article about the Camry or the Avalon? The Gadget Guru has repeated an extensive review here of what he sees as issues with the Avalon's GPS in 6 consecutive posts starting here: thegadgetguru, "Avalon Electronics" #18, 10 Jul 2006 10:34 am.
    It's very possible that the 06 Avalon has the same GPS system as the 07 Camry, but unless you know that for sure, you probably want to get that confirmed. And if I were you, I'd also ask the folks hanging out in the Toyota Camry: Navigation discussion what their experiences have been.
    Keep us posted on your research and decisions.
  • bv050506bv050506 Posts: 97
    I had a 2004 Maxima, a fine car. I now own a 2007 Camry XLS. The Camry is a better car, the Nissan looks cooler. The turning radius drove me absolutely insane! The Camry V6 is quicker than the Nissan VQV6, but doesn't sound as mocho when you get on it. ( 6.1 vs. 6.5 0-60) I also opted for the Bose system and sacrificed the sunroof. Bad move on my part, the panel in the Maxima while cool, isn't a sunroof, and if your used to one and like it, the glass panel won't excite you. I live in the north and one very interesting fact about the Maxima was it went through snow like it had 4-wheel drive. Haven't had my Camry in snow yet. The Max was bigger, especially the trunk that could swallow 4 sets of golf clubs easily, and the rear seat. The Camry is finished better and remember it has a 6 speed and gets great gas mileage, far superior to the Max. You gotta love that quad exhaust tho! Either way you'll have agreat car, so enjoy the ride!
    Camry is a nice car and is known for reliabilty. But you are comparing a 2004 Max to a fully redesign 2007 Camry. It don't seem fair to me. Both cars are great but the Max's turning radius is starting to get to me. The 6-speed is nice for the camry but I would prefer the cvt on the 07 max. The dual exhaust on the camry v6 is not bad either. And 18-inch wheels on the max.
    You're right, perhaps not a fair comparison. I haven't experienced the CVT tranny yet but must do it. Yes the 18's on the Max are stylin' for sure. I think the Max is a sexier car for sure. I'll test drive a new Max the next time I'm close to a dealer just to see how much it has improved since my '04. The exhaust on my Camry was made big enough by toyota to notice. The duals on a Fusion/Milan are hardly visual when you see them. I'll bet if the Max had 16's or even 17's the turning radius issue would go away. there just isn't enough clearance in the whell wells to allow for more turn. Do you have the new Max with CVT? How is it? Enjoy your ride!
    Unfortunately I just bought my wife a 2006 SE couple months ago. Neighbor got a blue SE camry so it's between the TL or Avalon and we ended up with a max(lol). Had a murano w/ CVT for rental feels weird but it drives nice through the mountains. Funny coz I never did notice fusion/milan had dual exhaust. You can put 18's on a camry and still would'nt have a problem making a u-turn on a narrow street.
    she'll like the Max, its a real looker and rides well. My Avalon was very nice, just didn't like how it handled. The TL is really superb but about $3K more than an avalon. I still think my Camry is a better car than the Avalon was, mostly because of handling. It's not a TL though. Nissan better watch out they're getting to a point where others are in superior cars. I put wider tires on the Camry as soon as I got it and that helped a bunch. I don't think 18's will fir but a 17 will.
  • thenebeanthenebean Posts: 1,124
    if i am not mistaken, i think the turning radius has a lot to do with the suspension on the car, and being that nissan put a sport suspension on the maxima, you get less of a turning radius because of it (though wheel size probably affects it too)
    something to consider...
    im a nissan nut, had a 92 max that i loved loved loved!!! if i had the money when i bought a new car 3 years ago, it would have been a max, but being fresh out of college, i went for a sentra ser spec v (which has a larger turning radius than the regular sentra due to the sport suspension) but i deal, i'll take a bad turning radius for the sporty feel!
    -thene :)
  • I think all the problems that you guys are saying about the Maxima has to be related with the way you maintain the car and drive it. I had a 2000 Maxima SE 5 Spd and never had problems with it. I kept it well maintained and serviced it. The oil i used was synthetic and the clutch lasted till 85,000 miles thats quite a lot. my brake pads lasted untill i traded the car for a 2004 Maxima SE Automatic. These one already has 28,000 and the only problem i have is that it dosen't turn. Then any other issues none. I also put syntheic oil and 93 otane fuel in it. The car is perfect and would not prefer any other.
    Mine was a 2004 SE as well. The turning radius issue got to be too much for me. Otherwise it was an excellent vehicle and I had no problems. Put a billet grille on mine and got rid of the toothed thing it came with. It REALLY added a lopt to the looks. Easy to install!!!
  • Turning radius is really lousy. This is my 3 Maxima (94,99,04) and probably my last. Had to replace rear breaks, discs etc after 27000 miles fronts at 36 000, the electric engine mount, rear right bearing at 36 000.
    I guess the one thing that I don't like is if I leave the car in the driveway for a awhile (5 days) rust starts to form on the discs (front and rear) and sometimes that rust feels like the discs are warped. I was "lucky" the dealer replaced the front discs before the 12000 miles limit. Front tires had to be replaced because of mis-alignment on the dealer part. (those 18 inch tires are very expensive.)
    I have a Jeep Wrangler that I store in the winter in my backyard for the past 7 years. I never had to worry about rust on discs.
«134
Nissan Maxima vs. Toyota Camry - Car Forums at Edmunds.com
