Yellow Exclamation Point Error on my Toyota Highlander
toyotalost2006
Member Posts: 2
in Toyota
Hi I need some assistance. I have a 2005 Toyota Highlander but I do not have the manual. Yesterday a strange thing happened to me. A YELLOW Exclamation Point surrounded by parenthesis lit up on my dashboard. This “error” is located above the Heat/Temperature display in the dashboard, away from where the check Engine light comes up. Does anyone know what this means? I called a Toyota dealership and all I could get was bring it in for check up. No further explanation.
Larry
I could be way off on this, but that was my understanding anyway.
From TW-11 of Toyota Camry Service manual ......"A tire pressure warning valve and transmitter is equipped with a tire pressure sensor and a transmitter and installed in a tire wheel assembly. The sensor measures the tire pressure. The measured value and transmitter ID are transmitted to the tire pressure warning antenna and receiver......., the ECU compares the measured air pressure value with the standard value. When the value is less than the standard value registered in the tire pressure monitor ECU, the warning light on the combination meter comes on."
By the way as a tidbit, these batteries in the sensors are supposed to last approximately 5 years.
http://www.tundrasolutions.com/forums/highlander/77665-2006-highlander-low-tire-- - - - pressure-indicator/
The Highlander uses an Indirect Tire Pressure Monitoring System versus Direct type.
There is no transponder in the air valve. The H/L uses a plain tire old valve. Thus, there is no PSI reading done by this Indirect Type System. It uses the ABS speed sensors to calculate differences of tire rotational speed among the Four rolling tires(the Spare is not included).
When the spare tire is put on, say when yu get a flat tire, the TPMS button must be pressed. (Recalibrated)
Direct Type TPMS costs more for Toyota and only puts it on select models. But for Toyota, the Indirect System meets DOT's TPMS mandated minimum Requirements for 2007 vehicles.
The Direct type system uses a transponder/PSI reader type Air Valve on each tire(including the Spare). Each of the 5 tires send a reading of the PSI to the reciever in the Vehicles TPMS ECU. It has a small battery and is self powered. Battery must be replaced when yu replace your tires. It must be carefully mounted. Each tire has it's owner frequency channel and ID. for it to be recognized by the ECU. This system is more precise. But has it's own set problems as a result.
I just wanted to express my surprise and delight to find this forum. After a dozen or more years on the Internet I should think to do a WWW search any time I have a question on any subject. Sometimes it takes a while to occur to me.
I have a 2005 Highlander, purchased in January, 2004. It has 16K miles on it. (No snickering; I'm old, OK?)
I had my first flat tire last week. There was a time when I would have put the spare on myself, but why do I pay AAA dues if not to spare me the dirt and aggravation?
I took the flat to the only tire shop in this small, desert town and picked it up the next day. The spare is still on the car. (I was pleased to notice that the Highlander has a full-size spare. However, I'm not sure I could have found and deployed it without referring to the Owner's Guide.)
The TPWS light came on at some point after the spare was installed; I'm not sure when.
Due to the poor organization of the owner's manual it took me 20 minutes to find the information about re-setting the system. The illustration was so poor that I was looking for the button on the steering wheel ... then the dash below the steering wheel . . . finally under the dash, where I found it. Just those three little words, "under the dash", would have saved me another five minutes.
Imagine my surprise when the light came on again after about a half-hour of driving. Several re-sets have had the same result.
I'm due for regular service (I use the dealer in a nearby town), so I guess I'll let them handle it. However, I wanted to understand the system before dealing with them.
The two theories as to how the system works have me intrigued.
If an RPM sensor were used, then there would have to be some sort of averaging system to preclude the false errors when turning a corner.
I'm also wondering whether either system would be easier to design to handle over-pressure as well as under.
DLM
